Question about Kitchen Appliances - Others
How to fix/ replace thermal fuse of aroma digital rice cooker?
early1234
  • 871 Answers
SOURCE: rice cooker stopped working after one month's use
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
Posted on Jan 17, 2008
dutchman05
  • 487 Answers
SOURCE: farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
Posted on Jun 24, 2008
SOURCE: I accidentally put the rice into the outer pot
The problem has been solved - the bottom cover of the rice cooker was unscrewed and pried off, and after removing the insulation, etc. the rice was removed.
Posted on Feb 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: need manual for Aroma rice cooker and steamer
CLICK HERE
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 14, 2009
SOURCE: Rice cooker Thermal fuse blows after one time use
Where Can I buy Tatung rice cooker inner pot?
Posted on Jan 05, 2010
Can i use the aroma rice cooker w/ 220v?
All you need is a power converter. Go to amazon and put in the search bar 220 volt power converter.
Best regards,
Bill
Oct 25, 2014 | Aroma Rice Cooker ARC-914sbd 8-Cup Cooked...
IM IN LONDON. I PURCHASED AROMA RICE COOKER THROUGH AMAZON.120V RICE COOKER. How to use it here in London?
Look on the information label to see how many amps it draws at 120 volts. Multiply the amps by 120 to get watts. Next you'll need to get a transformer that will handle the watts when changing 240 volts to 120 volts
Oct 10, 2014 | Aroma Rice Cooker ARC-150sb 20-Cup Cooked...
Error code e1
likely you blew your thermal cutoff. You need to replace that part. They usually have a temperature rating on them and you can replace it with any after-market part from any electronics parts or appliance parts place.
Nov 10, 2013 | Aroma ARC-914S 8-Cup Rice Cooker
I have an aroma rice cooker model #arc-150sb c1 displays on cooker and no buttons work, can't eat broke collage student. Need to fix asap.
Thermal Fuse Problem.
If there is no heat/power, check the continuity o the thermal fuse( white resistor type in the internal wiring connections ). Unscrew and open the cooker at the bottom side.
Replace it w/ similar temp. value.
DON'T SOLDER IT!
Hope that helps you out!
Sep 21, 2011 | Kitchen Appliances - Others
I have rice cooker i cant cook rice.i am on the cooker 5minute going tourn off
U mean, the rice cooker turns OFF after 5minutes?
Sounds like THERMAL adjustment needed!
Nov 05, 2010 | Aroma ARC-717G 14-Cup Rice Cooker
Does my Aroma rice cooker have a fuse?
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
May 27, 2010 | Aroma ARC830 6Cup Rice Cooker
ARC-838TC 20-Cup Rice Cooker: Lost the instructions on how to use the aroma arc ...
heatman101
May 18, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
3 CUP AROMA RICE COOKER WILL NOT HEAT --ONLY 4 MONTHS OLD
1. Is the cooking pot filled with water? If there is no weight, it will not turn on.
2. Is there a pilot light? If no power, you have a unit that was probably returned by someone else.
3. The heating element/plate thermal fuse may be blown. Either replace the fuse or the whole unit.
Mar 06, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
94 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
