Question about Samsung Cell Phones
How to disable password and phone lock keys - Samsung Cell Phones
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,891 Answers
Depending on device model; but, ususally it's under "Security" tab.
Posted on Nov 22, 2014
Pass lock reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Nov 05, 2013 | Precor Exercise & Fitness
Changing passwords on a used D 307.
Try this:
1. Reset to original factory setting by typing *2767*3855#, youre phone will reboot
2. Then insert a sim card that is from another network that your phone is not locked to.
3. An Wrong sim message will come up on the screen
4. When message appears type in* #9998*3323#
5. At this time a white screen will appear which says “exit”
6. Tap the rigth soft key, (occasionally it will not go to the next screen, if so press the down key)
7. From the menu that appears scroll down to the malloc Fail option, this will reboot, and normal service screen will appear.
8. Then type *0141# and press the green call key, Personalized will appear on the screen, and the name of the current sim card provider will appear on the screen.
9. Turn phone off, and then turn on
10. Go to menu by tapping left soft key, then settings in bottom right hand corner, then choose option number 7 security, then choose option number 6 Sim Lock, select option 1 disable
11. Then enter 00000000 (eight zeros), the message will come up sim lock disabled with a check mark, your phone is now unlocked to use with other carriers.
Dec 24, 2007 | Cell Phones
Nokia C6-00, I have disabled the Autokeyguard, still the phone is getting locked automatically at a very short interval.
Hi, there are two options for you to lock your cell phone under "Key Guard Settings", One is the "Automatic Key Guard" where you can set the delay time to lock the phone, and the other one is "Key Guard Code" where you can set a password every time you wish to unlock your phone. I think you have only disabled the Key Guard Code, please try turning OFF the Automatic Key Guard. I hope this helps.
Thanks for using FixYa.
Sep 08, 2011 | Cell Phones
I forgot the password of my ego iomega encrypt plus and the admin password is also locked ... how do I access the disk ...I am unable to even format it
Last time, when my Samsung mobile phone was locked by password, I also forgot the password and tried to disable the password protection functions by using the ways searched over the internet.
Maybe it may also work for your iOMega mobile phone.
Read more here:
How to disable android phone password protection
Aug 02, 2011 | Iomega eGo Portable Hard drive 500 GB ...
I have forgotton my lock screen pattern, how do i get my gmail and password?
lock screen pattern and gmail password is not related. but if you forgot the lock pattern u can reset or disable it with gmail id and password. If you draw the incorrect pattern five times you will get a message press OK. u can see a new button on screen below the pattern named "forgot pattern?". Touch this button to reset or remove the pattern with gmail id and password.
Mar 18, 2011 | HTC Wildfire Cell Phone
Lost phone password
*#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF
Jun 14, 2010 | Samsung SGH-A877 Impression Cell Phone
Nokia 3110 Clasic keypad is locked and I forgot my password! Please help me!
Friend you can disable the password throug removing the attachement of the keypad interface. try to detached it in a second then installed it once again and it will disable the locked. You can fine the interface underneath the key board. Use T6 screwdriver to open it. good l uck friend
Jun 16, 2009 | Nokia 3110 Cellular Phone
I forgot password on samsung sgh j210.. it as
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. j700 unlock method Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Mar 28, 2009 | Samsung SGH-J600 Cellular Phone
Iphone is disabled
I read a tutorial on disable iPhone backup password, hope it help you:
http://www.windowspasswordsrecovery.com/iphone/disable-backup-password-in-itunes.html
Jul 28, 2008 | Apple iPhone Smartphone
Password forgotten nokia n73 memory card
After restore setting know My Nokia N73 Memory card is on Password and I am not forget my Memory card password help me
Jul 22, 2008 | Nokia N73 Cellular Phone
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
