Question about HP Computers & Internet
Remove imapp error from hp laptop pc
How to remove imapp error from my hp laptop using windows 8 operation system
    New Friend:
  • 29 Answers
Sounds like it's to do with Incredimail Walter. I presume you have this, so uninstall Incredimail. Go to the Incredimail website and re-download and re-install the program.
You won't lose any settings by doing this.
Hope it helps.
Posted on Nov 19, 2014
CowboysFanZ
  • 99 Answers
SOURCE: error loading operating system
Here you go! SYMPTOMS loadTOCNode(1, 'symptoms'); When you restart your computer after the file-copy portion of Windows XP Setup, you may receive the following error message: Error loading operating system
CAUSE loadTOCNode(1, 'cause'); This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP. uparrow.gif RESOLUTION loadTOCNode(1, 'resolution'); Warning This article contains steps that may involve changing your BIOS or complementary metal oxide semiconductor (CMOS) settings or that may require you to make physical changes to your computer hardware. Incorrect changes to the BIOS of your computer may create serious problems. Microsoft cannot guarantee that problems that result from changes to your BIOS can be resolved. Change your BIOS settings at your own risk. If you need help with any of these steps, contact your hardware manufacturer and note that making either hardware or BIOS changes to your computer may invalidate your warranty. If you do not want to make hardware changes to your computer, you can take your computer to a repair center.
To resolve this issue, use one of the following methods: • Make sure that you are using the latest BIOS revision for your computer. Contact the computer manufacturer to inquire about how to obtain and install the latest BIOS update that is available for the computer. • If you are using an IBM computer with an AWARD BIOS version 4.5x, visit the following IBM Web site: http://www.pc.ibm.com/ww/hdd/hddredirect.html (http://www.pc.ibm.com/ww/hdd/hddredirect.html)Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
Posted on Apr 25, 2008
mailtoravi
  • 186 Answers
SOURCE: hp pavillion dv 1000 notebook
If  the Hard Drive self test utility is unable to detect the Hard Drive, the Hard Drive in your Notebook might have gone bad.
I recommend you to try removing and reseating the Hard Drive by getting the instructions from the Manual of the Notebook which can be accessed from the link below so that if there is any issue with the Connectivity, this should solve the issue:
http://h10032.www1.hp.com/ctg/Manual/c00636251.pdf
You can find the necessary instructions to remove and replace the Hard Drive in the Notebook from page numbers 120 of 258 in the manual.
Hope this helps...
Posted on Oct 15, 2008
hdpanama
  • 65 Answers
SOURCE: ''error loading operating system'' on Nec Versa laptop.
First if you haven't already unplug the power and take out the battery for a minute or so. Then reinstall the battery and connect power. Then try and start in Safe Mode, To do this start consistently pressing and releasing the F8 key while pc is powering on, continue until screen should display a similar screen as when turning on normally. From there ( hopefully it has started up ) you should be able to go to START MENU> click/open Control Panel> click/open ADD OR REMOVE PROGRAMS and start removing any programs, if not all, that look like they are using a lot of memory. Doing the SYSTEM RECOVERY is going to uninstall EVERYTHING and reinstall it anyway. Also remember you can only have one security program running other wise they will conflict with each other and cause numerous problems.
Clear temporary files and browsing history. Open IE, even if you don't ever use it, open TOOLS> open INTERNET OPTIONS> In the BROWSING HISTORY section click DELETE > Then click DELETE ALL
One other thing you may want to do is START MENU> RIght click MY COMPUTER> click PROPERTIES> click ADVANCED> click SETTINGS in the PERFORMANCE box and select 'LET WINDOWS CHOOSE WHAT'S BEST FOR MY COMPUTER'
Hope this helps.
Posted on Nov 18, 2008
SOURCE: hp compaq cq 40 108 tu laptop can i get audio video drive
can i get solution to install win xp on compaq cq 40-108
Posted on Jan 14, 2009
small6363
  • 18424 Answers
SOURCE: My laptop is a bran new hp 2000-2b09wm note book windows 8 pc
try this if it does'nt work go back to were you bought it from and they will sort it for you for free,..it could be somting to do with the DNS settings,,
After all the things that I was trying, I had gone through and reset
the router and modem, not just by turning them off, but by depressing
the tiny reset button on the bottoms. This wasn't actually the
solution. In fact, it screwed up the modem and router so I had to go
back and manually set them up again, step by step. While doing so, my
mom told me about a the Linksys site www.linksys.com/check. Here
there was a variety of tools to streamline the installation process.
Again, didn't actually solve my problem of being able to access
webpages. But, while on that site, I saw a router firmware upgrade.
Looks like my router firmware was out of date. So, I
upgraded................problem solved.
I still don't understand why I could access everything google....and
other computers using the same router and adsl modem still worked
Posted on Nov 29, 2012
How do i connect magic jack to my hp chromebook 14
Hello, This excerpt is straight from magicjack's website. Chromebook does not use any of those operating systems, it uses Chrome OS. This is not to say that it will remain that way but, this is the current state of their operating system support.
Your Question What operating systems does magicJack support? Category: All > Compatibility
print_icon.gif Print Article ' email_icon.gif Email Link tab_l.gif Answer tab_r.gif magicJack supports the most popular operating systems in the world:
  • Microsoft Windows XP
  • Microsoft Windows Vista
  • Microsoft Windows 7
  • Microsoft Windows 8
  • Intel-Based Apple Mac
Oct 21, 2014 | HP Pavilion 14 Chromebook 14-c025us - 14"...
Reset to factory settings
The procedure to reset your laptop to factory settings may vary depending upon the operating system you use. As you have not mentioned about which operating system you use, you can refer to one of the following HP support links that suit your operating system:
For Windows 8:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03489643&tmp_task=solveCategory&cc=us&dlc=en&lc=en
For Windows 7:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01867418&tmp_task=solveCategory&cc=uk&dlc=en&lc=en&os=4063
For Windows Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809678&tmp_task=solveCategory&cc=uk&dlc=en&lang=en&lc=en&os=4062
For Windows XP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07145&lc=en&cc=us&dlc=en
Hope this will help you.
GuruAid.com
Aug 21, 2014 | HP Computers & Internet
My laptop operating system failed to start it has an error code: 0xc0000001
It is probably a hard drive failure and will either require the operating system to be repaired, rebuild or at worst case the hard drive to be replaced and then the operating system to be reinstalled.
It is impossible to go further without expert examination so I advise you to find a reputable repair man.
Hp dv9208nr with vist sp2, system keeps rebooting, screen stays blank, cant even get to bios
hi,
When the files in your system are corrupted, your HP laptop would reboot automatically. When the files which are required to run the Operating System like fonts under Windows FONTS directory are been smashed then your system's Operating System will force your HP Laptops to restart continuously. Thus in such a situation you would have to change the name FONTS in the Windows directory.
Get more help to fix HP Laptop Keeps Rebooting error . Hope this helps you.
Apr 24, 2011 | HP Pavilion dv9000z Notebook
My hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator...
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
Forgot password to hp laptop how do i reset it.
I don't know what OS your HP laptop is installed with.
If it is Windows 8, Windows Password Hint, PIN code, Microsoft account can be used to login HP laptop. After logon successfully, change, recover or reset Windows 8 password is available.
If it is Windows 7, Password hint or another administrator account may help you. But if you don't have all of these, try password reset disk. Create it before Windows 8 locked or with Windows 8 Password Recovery tool is OK.
Besides these, Chntpw USB disk also works for Windows 7/Vista etc.
Mar 09, 2009 | HP Compaq nx5000 Notebook
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Computers & Internet Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
