Cs-21m16ml tv has lines lower half of screen and screen height slightly reduced and non linear. help
  • Televison & ... Master
  • 10,045 Answers
You're losing your high voltage to the picture tube. Have it checked at a repair shop. The voltages present on the tube will knock you on your a** if you're not careful.
Posted on Nov 17, 2014
techman
  • 3130 Answers
SOURCE: tv screen
HHHHMMM Never heard of goodmans But if its a 14" tv those are one sale for 69.00 in K-mart Well the 13 " is. Sounds like the vert output is bad or a capacitor in the vert out curcuit. good Luck
Posted on Apr 25, 2006
techman
  • 3130 Answers
SOURCE: TV vertical height-Mitsubishi Model CS 35505
If the height has dropped down, you need to first find out why. Most likely there is a bad capacitor in the sweep power supply or the vertical output section. Good Luck
Posted on Oct 17, 2007
Siestamagic
  • 6 Answers
SOURCE: horiz. lines across top of screen.
I agree with solution #2
I recently had my phillips 27" model 27PT6341/07 repaired after warranty expired due to white lines appearing at the top of the screen. The shop advised that it was a capacitor giving me the problem. So, after getting it back, I examined the repair job and the shop had replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v. I was told that it would fail again soon because it is a manufactures defect. For me it is at location 2465. Here are a couple of photos of the part.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
Good luck,
Ed
Posted on Mar 16, 2008
johnnydiode
  • 647 Answers
SOURCE: the picture on the screen has reduced to a half inch
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks
Posted on Oct 05, 2009
SOURCE: 27'' lxi reduced picture
I have a tv odor model 580 43608190 and my screen has this line in the middle of my screen so every time I have to hit to see the picture. What does that mean
Posted on Nov 16, 2011
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do I adjust the screen to the TV - I've looked in the MENU options and can not adjust the height of the screen. In other words - I can not read the score ticker on the bottom of the screen
Your sanyo tv may have service mode adjustments. It can be taken according to the sevice code options, which can be get from service journals available in the market. no menu adustment is there to adjust the picure linearity, height , subbrightness control so on. All adjustments are coded and have critical measurements which can be adjusted through service mode with the help of remote control. The remote control should be orginal to access service mode. Duplicate may not work properly.
Oct 14, 2010 | Sanyo DS24425 24" TV
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
Vertical line at edge of AV1 channel
hi! he might have adjusted the vertical hold and height including the linearity. normally on the board you would see a trimmer resistor with a label v-hold this is to stop the rolling, v- height for the size of the picture. and linearity for the evenness of the picture from top to bottom.
Aug 28, 2009 | Televison & Video
Vertical distortion
try to replace all capacitor in vertical section a leak capacitor can make your screen to shrink....
Sep 12, 2008 | NEC AccuSync 90 19 in.CRT Conventional...
TV not working properly
You have a vertical problem. See if there are any vertical (height or linearity) controls to adjust. Often there will be screws or knobs on the back.
Otherwise, it could be bad transistor or component in the vertical-deflection circuitry.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Oct 16, 2007 | Mitsubishi CS-36609 36" TV
Televison & Video Logo
Top Televison & Video Experts
