Question about Roku 3
I can't connect to my internet. I don't know the correct password.
    Habit-Forming:
  • Roku Expert
  • 94 Answers
You will need to login to your wireless router to get, or set, your network password. A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information. User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
If your successful at loging-in, you need to look at your wireless settings, under one of the sub-tabs you should find a password field indicating your network password. This is what should allow you to login to your network with your Roku device.
Posted on Dec 16, 2014
How do I connect to the internet using a wireless network if I don't know the password?
You should be able to contact your service provider and reset your password.
Feb 21, 2012 | Coby Kyros 716829701508 Tablet PC
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
I have an error coming up on my screen for the wii saying unable to connect to the internet error 51330
The error 51330 normally means that the password or WEP key you entered to connect to the internet through the Wii did not match the one the wireless router needs to allow connection.
If you don't know the password, check to bottom of your router, it will usually have a sticker on the bottom with the standard password on it. This can also be marked as WEP key or WPA key. Enter that password exactly as it appears there, as it is case sensitive. If the password is correct and the problem still exists, try turning your router off, waiting 30 seconds to a minute, then turning it back on. Let it set itself up again, this will usually take a minute or two, then try connecting your Wii to the internet again. If the problem continues, try altering your routers wireless channel setting. As most routers work on channel 6 by default, there could be interference. This process is different for each router.
Jul 13, 2011 | Nintendo Wii Console
Error code 51330 unable to connect to the internet choose internet setting and then confirm your connection then it is tellin me to vist this sit i am wondering cam u help
My laptop is 2 months old and suddenly cannot connect to the internet. i have mobile and wireless internet and neither works for my laptop. Connectivity is fine for other PC's in my house hold.
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps don
Feb 27, 2011 | Acer Aspire 4520-5582 Notebook
I cant open my internet explorer..
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
or if this is what you mean
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
don
Feb 19, 2011 | Computers & Internet
Need to access the internet but keeps saying that it cant establish a connection
also
hope this helps
don
Feb 19, 2011 | MetroBook VL Plus C-266 Notebook
Cannot connect internet
hi,
install the network driver package included in your motherboard.
Feb 16, 2011 | Asrock K8NF4G-SATA2 Motherboard
Why can't I connect to the internet?' I have tried to reset the modem, but has not worked
also
hope this helps
don
Feb 16, 2011 | Computers & Internet
Cant login to the internet
also
hope this helps
don
Feb 14, 2011 | Computers & Internet
Roku 3 Logo
89 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
