Firstly, CAN??, and then how do I get an NEC NLT-19XT1 television to work with a TEAC High Definition Digital Receiver HDB848 HDMI, please. Anyone know how? Appreciate all the help I can get. Thank
Firstly, CAN??, and then how do I get an NEC NLT-19XT1 television to work with a TEAC High Definition Digital Receiver HDB848 HDMI, please. Anyone know how? Appreciate all the help I can get. Thank you.
    Novelist:
  • 176 Answers
Id the TV Anolog or Digital? If it is analog, then the digital receiver must have RCA outputs to meet the TV's RCA inputs. To make an old analog TV work (meaning getting a picture), you have to check id the receiver has RCA or S-Video outputs. If so, then connect an RCA cable with yellow into yellow, red into red and white into white and then connect the same colors plugs to the yellow, red and white to the RCA inputs of the TV. Or, you can connect a S-Video cable plugs in the output of the receiver and the input of the TV, disconnect the yellow RCA plugs at both the receiver and TV sockets and leave the red and white cable for sound only, as S-Video has an improved video signal, therefore better picture quality. On the TV you have to select an AV input channel, like AV1 or AV2, etc. The same channels that you had used when you were once watching VCR tapes on analog TV. Hope this helps.
Posted on Nov 17, 2014
sandrew
  • 2961 Answers
SOURCE: Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Posted on Oct 14, 2007
  • 520 Answers
SOURCE: Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Posted on Nov 05, 2008
jsinex2421
  • 62 Answers
SOURCE: which is the best high definition television& why.
It depends on your needs really. I enjoy the sharpest piture. So I choose DLP tlevisions. They have a downside. They are about 13' thick. But the resolutuion is almost twice as good as an LCD. A LCD gives you excellent picture quality, and is very thin. Averages about 4". You want a television that has a refresh rate of 120hz or higher. Sony just introduced a model that has a 240hz refresh rate. This is advantagous for sports fans becuse the refresh rate is critical. If it has less than 120 hz then the faster the oblect moves on the screen, there will be a little blur. Any 1080p HD television is going to give you a superb picture. The brand is purely a loyalty issue. Sony Bravia LCD's seem to have a very low rate of problems. And they are very affordable. I enjoy DLP better because I am more into watching movies, and they have the purest colr/picture with no possability of "burn in" Plasma is the WORST choice. They are prctically unserviceable. Or, they cost too much to service. Sometimes itis cheaper to buy a new plasma than to have one repaired. The only draw back on my DLP is that I have to replace the bulb at about 100.00 every 4,000 hours of viewing. Dlp's are also famous for having color wheel issues. After a copule of years they will start to make a metallic screech, or hum. But If you purchase a 5 year warranty they get replaced for free. As long as you buy a 1080p TV with a 120hz refresh rate or higher, you will be VERY satisfied. And you will have the latest in technology.
Posted on Jan 13, 2009
diodeic
  • 1622 Answers
SOURCE: NEC - Model NLT-32HDB2. The DTV (digital receiver)
You can fix this, all that is needed is to carefully understanding the electronics parts used and having little of basic knowledge in electronics.
The problem is in either power supply or the Y sustain board. The Y sustain board is are relatively large board if out of which go connections to the side of the display , it therefore closer to either the left or the right side of the display , has at least one rather large heat sink on it and far power cables connecting it to the mains power supply .
Often there are fuses on that board , one or more , check them
If they are blown you can try to replace them, but expect them to blow again , usually the whole board needs to be replaced.
Often that need to be done in a service center as there are some adjustment to be made after replacement.
Posted on Aug 22, 2010
hmerchant110
  • 7191 Answers
SOURCE: Where can I get a
You can view, download and print the instruction manual for NEC NLT-20G in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Your feedback is important to us!
Kindly rate and accept the solution if it helps you.
Posted on Jun 14, 2011
Tip
HDTV HDMI hookup
Connect a HDMI cable from your source device (cable box, Bluray, satellite receiver) to your HDTV for High Def video and audio. This is the best hookup for HD, even 1080p. For 3D HDTV, make sure to get a high-speed category 2 HDMI cable. Select proper HDMI input on the TV using the remote. HDMI means High Definition Multimedia Interface.
Any newer digital TV (made after 2008) should have at least one HDMI input.
https://sites.google.com/site/columbiaisa/diagrams_hookup_hdtv_hdmi
HDMI Cable
on Mar 06, 2011 | Televison & Video
What does error code AO 38 or RO 38 mean with a TEAC HDB848 digital receiver?
http://www.teac.com.au/support/ You need to contact them. You can use email. There is no information forthcoming on the issue.
Oct 09, 2014 | Teac Audio Players & Recorders
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
Mar 27, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
What is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
Can I get HD Channels on an NEC LCD TV(NLT - 19SDEM3)??
The 19SDEM3 is a standard definition TV so no HD.
Dec 26, 2010 | NEC Televison & Video
NEC - Model NLT-32HDB2. The DTV (digital receiver) stops working after an hour of use - the television seems to have lost all trace of the DTV settings. The analogue and the other inputs (eg AV HDMI) are...
Aug 22, 2010 | NEC 19 in. LCD TV
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
I have a problem with using the HDMI
Please make sure that your receiver can display high definition signal, such as 720P, 1080P. As you know your HDTV is high definition source, it can only be displayed on the display machine that have ability to display high definition HDTV signal.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
32" protron tv
an output like ( HDMI ) would be on a dish reciever , and a hdmi input on a tv would plug into that output on the dish reciever
Is HDMI what you are trying to connect? then you would need an HDMI cable
HDTV = High Definition television , which means that you have a built in digital tuner that will pick up the digital and high definition broadcast channels with an antenna connected to the tv
Mar 02, 2009 | Protron PLTV3250 32 in. LCD Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
