Question about Garden
How can I rectify a Karcher G2500 Performance series water blaster that pulses in the hose when it is turned on & has lost half the pressure?
Petrol motor runs OK but pump does not
    Sergeant:
  • 429 Answers
Either you have a check valve stuck open and or closed(normally under a hex plug normally three plug heads have two under each if six plugs is one under each plug)remove any obstruction if found ensure your inlet strainer is utilized for prevention of foreign substsance..you may also have a ruptured seal
Posted on Nov 26, 2014
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
SOURCE: karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Posted on Jul 16, 2008
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 250 Answers
SOURCE: The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Posted on Sep 19, 2009
Testimonial: "Thankyou, great help!"
SOURCE: Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Posted on Mar 12, 2010
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
My karcher seems to pulse when on, could this be due to the low water pressure from the hose?
I do not have specific experience of your machine.
However, the high pressure pump will be controlled by a pressure switch on the high pressure outlet to the pipe and jet.
Pulsing (turning off) suggests that the outlet (high pressure) pipe is blocked or partially blocked. Try checking the nozzle and (with the unit turned off) clearing it with a fine piece of wire.
Hope this works
Nic Williamson
Apr 23, 2011 | Karcher K2.26 Electric Power Washer
Folks, I have a Karcher 5.55 home water blaster that pulses at the highest pressure on the vario power spray wand. It works fine on the lower pressure settings and with the rotary spray wand. I live in a...
There should be a pressure regulator somewhere in the pump, check your owners manual or go on mfg. Site and see if you can find your model.
Aug 05, 2017 | Karcher Garden
Hy; I have a karcher 580 I had to replace gun complete so I bough a simoniz xe01-001 at simoniz.osirus.ca/ for your info 69$ complete ***.I install NOW I get pulse up & down ONLY when trigger is press...
Most likely problem is that the tip is too small causing Unloader to bypass or restriction/debris in tip. Install clean tip of proper size or 1/2 size larger (example from 2.5 gpm to 3 gpm ) to prevent slow pulse. If tip is clean and /or larger tip does not help, Unloader may be failing if the unit has a good deal of hours or if machine is left running for long periods of time without spraying. Try lubing the internal parts by removing both hoses and installing a short piece of water hose to intake and slowly inject light oil into pump by pulling on the rope slowly to **** in the oil until it comes out the pressure side. This will displace all the water from inside the pump. Leave overnite. There is a kit sold on ebay to help facilitate the infusion of oil but no need to get fancy. Unloader repair kit is usually available if all else fails and is easy to install. Good holidays
Dec 12, 2010 | Karcher 2500 PSI Pressure Washer
Karcher K4.99M Started to pulse and lose pressure so changed cylinder head which appeared to have a hairline crack. Having reassembled it still pulses but something is restricting flow of water when I...
pulsations indicates an pressure controller suffering from a partially blocked jet at the wand end
blocks up p pressure drops off , unblocks starts pressure to repeat the cycle
Nov 25, 2017 | Karcher Garden
My Karcher 2.99 starts and stops, (pulses) when th...
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
Karcher pressure washer keeps pulsing when not in use and has lost pressure when in use
This can happen if the head of the pressure pump has split. You may need a new head, and to stop this happening again, tie the rigger open with a zippy tie. The water will run all time now and automatically bleed any air form the system. When you want pressure, turn it on at the main switch. This will prevent hydraulic hammer, (when you pull the rigge)r, which is what causes the head to split.
Mar 28, 2010 | Karcher Garden
I can't connect the garden hose to the water inlet. I am using a size 5/8'' hose but it wont connect to the unit. Please help!
Karcher electric pressure washers typically are supplied fitted with the male half of a standard Hozelock connector. You need the female half secured to the end of your hose, and then they just click together.
May 16, 2009 | Karcher PSI Electric Pressure Washer
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Mar 21, 2009 | Karcher Garden
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
