Question about Yamaha Audio Players & Recorders
What is the replacement of transistor 2sd 1915?
I have my problem about my yamaha av amplifier dsp-ax 2200 there is no power and the transistor d1915 was busted.
  • Yamaha Master
  • 9,587 Answers
Http://www.datasheetarchive.com/buy/2SD1915.html Costs 87 cents from MCM
Posted on Nov 17, 2014
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: looking to get hold of an instruction manual
http://www.retrevo.com/s/Yamaha-DSP-A595-Amps-review-manual/id/319ag821/t/1-2/
Register for free and download it.
Posted on Apr 28, 2009
SOURCE: av amplifier
The display problem is because the solderings on the back of the display are broken. To fix it you have to open the amp and redo the solderings (there are about 50 or 60 of them). There is a Youtube video that shows how to do it. I have fixed this on my DSP-A1.
I also have the problem with the motorized volume control. I have tried cleaning it, and it works for a few days, then it's stuck again. I guess I will have to replace it to have it fixed permanently. The part number is VZ621400, a new one costs about 40$.
Posted on Jun 23, 2009
  • 52 Answers
SOURCE: Yamaha AV Amplifier RX V530
You might have your speakers shorted. Check the wiring at the amp and speaker terminals
Posted on Sep 01, 2010
What is the replacement of transistor d1915
IS that a 2SD1915 or something else, it looks like an 2SA1022 or NTE2407crosses - Newark Electronics or Mouser might be able to provide you a different cross reference. There are data sheets that seem to indicate a A1022 / NTE 2407 - this one can be found here http://www.mouser.com/Search/Refine.aspx?Keyword=2SA1022 Amplifier Transistor - these are common I think for older amplifiers. If memory serves me right - I probably have a couple old ones I bought to fix a Reel to Reel .
Nov 17, 2014 | Peavey Pv 2600 Power Amplifier
Yamaha dsp ax 861se service manual for the amp
you can download this service manual free from here.
Thanks.
gylacz
Nov 28, 2012 | Yamaha Audio Players & Recorders
The sound of the LEFT MAIN Cannel disappears on my YAMAHA DSP AX-1
The fact that sound appears at max volume means that it is getting past and through the pre-amp stage. So it would appear to be in the main power amp stage the problem. It would depend what drives the channel, but if it's transistor driven I would suspect one of them.
Oct 31, 2012 | Yamaha DSP-AX1 10-Channel Amplifier
Audio thump on changing any parameter
My bet is a faulty electrolytic capacitor! Don't know which. but would look around the circuit of those stages.
May 30, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
Flashing LED on the volume
i have problem with amp yamaha dsp-a1000 the led the volume it like blinks everytime is good the transistor the output is good, i dont no whats happening can u help me please
Jul 19, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Dsp-a1000 dead
output stage problem, systems trips due to protection. have the power amp transistors checked. the rotating of function switch is normal, its like a routine system check
Jun 22, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha receiver RXV-1400 turning off after 3 seconds.
Hi
there are several reasons, but the most common is because a high power trasistor is shorted, most yamaha receivers use the same names for the failure signals, such as PRD, PRI, PRY
The PRI is the signal that "tells" to the microprocessor that something is wrong with the power amplifier stage. so my recommendation is that look with the ohmeter a power transistor shorted usually if one if damaged, the next one or complimentary is too, there is a small transistor between the two big ones, usually is the number is D1915, if this is damaged, USE the SAME, also look for resistors damaged, specially the low value like the big white this resistor is 2 in 1 and some times just one resistor opens.
I hope this helps
Miguel
Mar 15, 2008 | Yamaha RX-V2400 Receiver
Parts replacements
This is straight from the 1989 Japanese Transistor Substitution Manual.......
2SA 1011--------use 2SB 1085 A, made by Rohm
2SC2344---------use 2SD 1562A, made by Rohm
Good luck...Rob
Jan 31, 2008 | Audio Players & Recorders
Av amplifier
Jan 07, 2008 | Yamaha DSP-A1 Receiver
110 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
