I have a NEC vt491, after the normal start up there us a clicking noise from around the fan area, i think it's the ballast, then beeping and the power light goes orange than the standby starts blinking red, any help is appreciated
    New Friend:
  • 4 Answers
Maybe the cooling fan is not working CHK for any object blocking the fan blades like hair ect---
Posted on Dec 08, 2014
5 Suggested Answers
gopakumarg43
  • 75283 Answers
SOURCE: Status light is blinking red,
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Posted on Jan 03, 2012
SOURCE: No Picture on my nec VT676 model
Thanks. NEC did not have a solution for us, but the solution for us was to replace the bulb. You'd think they would make that a bit more obvious!
Thanks.
Posted on Mar 27, 2008
SOURCE: lamp won't light / status indicator blinking red
Replace the bulb.
Posted on Jun 10, 2009
projdoc
  • 2237 Answers
SOURCE: red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Posted on Sep 02, 2009
What to do?
1. Unplug projector and wait a minute or two. This will reset the projector.
2. Try a new (or a known-good) lamp.
3. Contact NEC. I wasn't able to find a service center in India, but here is a link to their global website:
http://www.necdisplay.com/global-locations
Jan 15, 2015 | NEC VT491 LCD Projector
Vt491 service manual
Are you looking for it or do you have the service manual?
Jan 17, 2013 | NEC VT491 LCD Projector
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT265 PROJECTOR WILL POWER UP BUT WILL NOT COME ON. BULB IS A YEAR OLD. WAS PLAYING A MOVIE WHEN IT WENT OFF AND WILL NOT COME BACK ON. NOR WIL THE FAN RUN. POSSIBLE BALLAST?
It cannot be a ballast because the fan would not run off a ballast. Sounds like a serious hardware failure, I would check with the manufacturer.
Mar 10, 2010 | NEC LT265 Multimedia Projector
Status lamp blinking orange 6 times
PROJECTOR. NEC VT491 THE STATUS LIGHT IS BLINKING 6 TIMES RED, AND THE POWER LIGHT IS ORANGE
Jun 26, 2009 | NEC Office Equipment & Supplies
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
VT491 Lamp not turning On
The error code of light blinking 6 times suggests it's the lamp and you have replaced it. Possibly remove it and reinstall it. Those lamps get very hot and fingerprints can leave an oil on the bulb which heats up and can destroy the bulb. Use a paper towel when handling them. Make sure the vents are not covered with dust and the unit isn't too hot. Do you have the manual? Here it is on pdf,
http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
once you open the site, you can click on control +F on your computer (Windows machine or Command F on MAC) That will bring up your "find" shortcut key. Then type in "error" to search. Good Luck
Nov 30, 2017 | NEC VT491 LCD Projector
242 people viewed this question
k24674
jasbo
jasbo
