Question about Chevrolet 2000 Chevrolet Venture
White smoke Hi , I have a 2000 Chevy venture I boutgh it 5 months ago, was working fine but last month I notice white smoke wen Im park the truck ( engine on) or wen I press the gas to get more speed but only some times is smooky , wen I'm on the freeway the van is ok. No smoke I been monitoring the oil, and coolant levels and are ok. I took it to a local mechanic he thing is not the engine because the smook is not all the time the replace the pcv valve but still doing sometimes grey smook. Could you helpme please
  • Chevrolet Master
  • 9,771 Answers
You need to replace the valve stem seals in the engine.
Posted on Nov 17, 2014
Testimonial: "What's the function of the valve stem?"
  • Lawrence Oravetz Nov 18, 2014
    Valve stems are the part of the valves(Intake and Exhaust) that the springs attach to. The rocker arms push down on them to open the valve to let air and fuel in and exhaust out. Since the top of the valve stem is outside the cylinder it is exposed to the heat and oil that lubricated the parts of the engine that reside unter the valve covers. Heat and a lot of miles will cause the seals to become brittle and lose their ability to keep excessive engine oil off the stems. When the fail, the high amount of vacuum present in the rocker covers is enough to let oil to be drawn into the cylinders at idle. When you accelerate the oil is then burned to produce white smoke. If your mechanic doesn't know this, then find another more educated mechanic.
  • viento86 Nov 18, 2014
    Thanks for your info. Is very helpful for my and I will find other mechanic. ??
Hi I got a Toyota corolla 160i gle and it was parked very long so wen i started it wen ideling no smoke BT wen hit da fuel it smokes and on take off BT wen driving it does nt smoke
Generally, it may smoke on startup for a few seconds then quit and seem to run fine, then you hit the gas and it smokes again, so Is it white smoke gray smoke or blue smoke? Because IMO it's either a bad head gasket, bad valve guides, rings are going bad ot dumping to much fuel into carb or injectors.
Mar 14, 2015 | Toyota Corolla Cars & Trucks
Electrical probrems
replace the relay. may be stuck.
May 26, 2013 | 1999 Dodge Durango
1995 Chevy Blazer Engine Frozen
The engine head gasket failed, this should not be a total engine seizure.
Apr 10, 2017 | 1995 Chevrolet Blazer
Oil on plugs that burn white smoke
I would`nt be too worried about the oil on spark plug threads be more concerned about white smoke! it sounds like head gasket problems.Good-luck.......
Jan 05, 2013 | 1997 Oldsmobile Aurora
White smoke coming out of tail pipe.
WHITE smoke? Or BLUE smoke? White smoke is usually caused by burning antifreeze (possible blown head gasket). Engine oil burning causes a bluish colored smoke.
Changing the oil two months ago means absolutely nothing to me. I have customers that travel 6000 miles or more in a month. Oil consumption is measured in volume over miles, not volume over months. It is normal for most 4 cylinder engines to use a little less than 1/2 quart in 1000 miles (even more than that for 6 cylinder and 8 cylinder engines).
Apr 12, 2012 | Cars & Trucks
2000 chevy venture overheating problems
Sounds like you still have a cooling system leak issue like a cracked cylinder head.
Mar 15, 2017 | 2000 Chevrolet Venture
Hi, My Sidekick starts to "putter" as i drive like it's not getting enough fuel. Then when I accelerate it blows large amounts of white smoke out the exhaust. It did this once before last summer...
White smoke always means that oil is getting into the cylinder. This will make the car sputter. You have to find out why the oil is getting in there. It needs to go to a mechanic because it could be any number of reasons why the oil is getting in.
Mar 24, 2011 | Suzuki Sidekick Cars & Trucks
I have a 1990 chevy pickup 5.7l v8 that made a loud noise when i was driving. Next the truck starting losing power and makes an engine tapping noise. I parked the truck.for several months and now tyin to...
Well, billowing white smoke from the tailpipe is generally antifreeze burning off in the engine, which would indicate either a blown head gasket into a cylinder or a broken fluid passage. In the old days there was a way an automatic transmission could leak trans fluid into the engine and create white smoke too, but that shouldn't apply to your vehicle. Not certain about the noises, but clearly you have some internal damage. You can check the antifreeze level to see if you have lost fluid. You can pull the spark plugs to see if you notice damage to the plugs or deposits on the plugs indicating antifreeze.
Dec 11, 2010 | Chevrolet 1500 Cars & Trucks
I have a 2000 pontiac grand am gt the check vehicle soon light has been on for a couple of month and jus recently the abs and trac off light needless to say i have had little to no problems with my car...
Wow!
The first thing you need to do is fill the coolant up again and take it to a shop that you trust,have them pressurize the coolant system to find the leak,then repair it.
But my fears are that who ever check it for you last saw a head gasket leaking and didn't want to fix it so said nothing,Also if your seeing white smoke behind you that is an engine burning antifreeze.
Nov 16, 2009 | Pontiac Grand Am Cars & Trucks
Chevrolet 2000 Chevrolet Venture Logo
83 people viewed this question
Top Chevrolet Electrical Supplies Experts
Lawrence Oravetz
jdthefixer
Mike Carew
Are you a Chevrolet Electrical Supply Expert? Answer questions, earn points and help others
