Samsung 5203 won't stay on
Took it out of the box, turned it on, was going through setup and it shut down a few time. Shen set up was finished, Tried watch TV and in about 30-40 secs it turns off
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
If power LED at its front panel is ON, the fault is with its main board. If it is OFF; the fault is with its main power regulator board, and related connection sockets. Check all the connection sockets, for any loose connections. Re-insert all of it once, and check. Contact any service technician. http://electronicshelponline.blogspot.com/
Posted on Nov 17, 2014
SOURCE: LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Posted on Mar 01, 2010
orionsecurit
SOURCE: My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Posted on Jul 08, 2010
  • 8457 Answers
SOURCE: 50" lg plasma tv when i turn it on it shuts down
The power supply board have problems,it not giving the tv the right votage anymore.That why it shutting down,not sustancening power to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power board for the replacement.
Posted on Oct 16, 2010
eagle338
  • 4889 Answers
SOURCE: Sony KDL-40V4100 when turned off
Can you please count the number of blinks in between each pause so that I can tell you what the problem is? Its a self-diagnostic error code that makes the diagnosis a lot easier
Posted on Mar 25, 2011
  • 10 Answers
SOURCE: My 42LD450 won't stay on! It
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
Posted on Jul 10, 2011
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Why my acer aspire e1-571 won't shutdown?
i would take it back straight away if you start messing with it they might accuse you of damaging it and decline the warranty on it....
Jan 04, 2013 | Acer Aspire E1-571-6650 Laptop
My 65" samsung turns off when i connect my laptop
Hi Spence,
Is the TV set to "VGA"? If the TV does not detect a signal, it won't stay on, only go to a sleep mode. Make sure the cable is securely connected to the TV as well. You may go to the settings and check the power saver settings, but I don't think this has anything to do with it, I only offer it as another avenue to pursue.
Best luck
Joe
Sep 20, 2011 | Dell Computers & Internet
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
The air conditioner stopped blowing air. It is still too hot for it to have shut off automatically, When I power it down & turn it back on it makes a noise but won't start blowing the cool air. The...
Your going ot have to shut it down and let it deice. remove the filter and replace it or wash it out . this might take a few hours so leave the indoor fan on it will speed thing up a bit. also set the temp to mid range and close all unused rooms off it has to cycle a bit but really my money is a dirty filter and ice.
Jul 19, 2011 | Heating & Cooling
Phone won't shut off. Display stays lit all the
The software got stuck whil shutting down. Try resetting it to factory defaults after saving your phone book and other valuable info on there.
Jun 26, 2011 | Samsung Cell Phones
My Yahoo Messenger hangs then it would say (not responding...). What can i do to fix this? Help me please?
Few sugesstions :
1) Check whether if your windows is installing new updates, sometimes YM does crash when window is updating. If you are using Win7, then just go to:
--> Control panel/ System & security/ Windows Update/ Change setting. In the setting panel, you will see " Important Updates " box selection. Change it to "Check for updates but let me choose whether to download & install them". Restart your pc/laptop, then try log in to your YM.
2) *This step won't be necessary but won't do any harm too, go to:
Control Panel --> System & Security --> System --> Advance System Settings. In the " Advance " tab, click "setting" at the " performance " column. Select " Data Execution Prevention ", select " Turn on DEP for all programs & services except those i select", Insert your YahooMessenger.exe (C:/Program Files/Yahoo!/Messenger/YahooMessenger) into the add list. Restart PC/laptop & try to log in to YM.
3) If those won't work, uninstall your current YM, restart your pc/laptop, then try installing a new one. Link : a)http://www.mydigitallife.info/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/ b) http://www.geckoandfly.com/6309/download-yahoo-messenger-10-full-offline-installer-15-8mb/
** If it still crash, then your internet connection might be the problem, & also, Yahoo! can be down sometimes too.
Jun 08, 2011 | Yahoo Messenger
I coudnt sign in the yahoo messenger,while i can sign in yahoomail.what could be the possiblem problem?could you suggest solutions
Few sugesstions :
1) Uninstall your current YM, restart your pc/laptop, then try installing a new one. Link : a)http://www.mydigitallife.info/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/ b) http://www.geckoandfly.com/6309/download-yahoo-messenger-10-full-offline-installer-15-8mb/
2) If it does not work, check whether if your windows is installing new updates, sometimes YM does crash when window is updating. If you are using Win7, then just go to: --> Control panel/ System & security/ Windows Update/ Change setting
3) *This step won't be necessary but won't do any harm too, go to Control Panel --> System & Security --> System --> Advance System Settings. In the " Advance " tab, click "setting" at the " performance " column. Select " Data Execution Prevention ", select " Turn on DEP for all programs & services except those i select", insert your YahooMessenger.exe (C:/Program Files/Yahoo!/Messenger/YahooMessenger) into the add list. Restart PC/laptop & try to log in to YM.
May 27, 2011 | Yahoo Messenger
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Vizio LCD 37 Inch Turns Off Randomly
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Jan 15, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
