I have a NEC vt491, I turn on the power, the power buttons green, fan wirs up sounds ok, then the standby starts blinking green and a light clicking comes from around the fan area, (I think its the ballast trying to make a circuit but discharging freely), than a beeping noise starts him off, the fan rpms go up and the power is orange and the standby is blinking red, I did everything the manual said and nothing had changed, so is it a bad ballast, lamp timing, the lamp, I just wanna knew what's wrong with it. Any answers are appreciated
  • 60 Answers
SOURCE: Zenith E44W46LCD 44 in. Rear won't start
The buzzing is the ballast for the lamp trying to light the bulb. From what you've described it is a lamp failure. It's not that hard to change but you'll have to obtain a new lamp first. You can try and buy it from LG (800-243-0000) but I'm not sure if they'll sell to a consumer. Then you have to reset the lamp timer after you replace it. Hold the mute on the remote and the enter button on the tv at the same time for about 8 seconds and a screen will come up asking if you want to reset the timer. Just follow what it says to reset it.
Posted on Jan 03, 2008
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
  • 3 Answers
SOURCE: Panasonic PT-45lc problem
I took the rear bottom off of the set,lots of screws to take off.
On top of the bulb housing is a small yellowish thermal fuse.
I took mine completey out,jumped the black wire together,and bingo.set works perfectly.
Posted on Apr 16, 2008
SOURCE: No picture, green light blinks then short buzz sound
I had the same problem with my TV. I called the Zenith support line and found out my model (E44W46LCD) had a manufacturer's defect and Zenith said they would be taking care of it. I am in the process of waiting for them to let me know how, but they took all of my info and said they would be responsible for fixing it.
Posted on Jul 09, 2008
  • 1527 Answers
SOURCE: lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
Posted on Oct 24, 2009
NEC lt240 lamp light stays off and power light is orange, no Image
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Status light is blinking red, power button orange nec vt700
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
I turn it on, the status light flashes... then it turns itself off, except the power button is still showing power and the status light is blinking red
Your bulb is not lighting.
Either the bulb has failed or it has a bad contact.
Remove the bulb to check condition and then reinsert and try again.
If it still does not light you will have to buy a new bulb.
Please dont forget to vote this answer was helpful.
Many thanks
Feb 28, 2011 | NEC VT491 LCD Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Status lamp blinking orange 6 times
Jun 26, 2009 | NEC Office Equipment & Supplies
VT491 Lamp not turning On
The error code of light blinking 6 times suggests it's the lamp and you have replaced it. Possibly remove it and reinstall it. Those lamps get very hot and fingerprints can leave an oil on the bulb which heats up and can destroy the bulb. Use a paper towel when handling them. Make sure the vents are not covered with dust and the unit isn't too hot. Do you have the manual? Here it is on pdf,
once you open the site, you can click on control +F on your computer (Windows machine or Command F on MAC) That will bring up your "find" shortcut key. Then type in "error" to search. Good Luck
Nov 30, 2017 | NEC VT491 LCD Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
