How can i fix my lap top battery circuit after fixing new cells?
I have inserted new cells in lap top battery, showing required voltage but circuit is not powering up lap top?
    Top Expert:
  • Computers & ... Master
  • 26,177 Answers
A very dangerous thing to do and possibly the pcboard and temperature sensor inside the battery is now damaged. Probably cheaper to buy a new battery through ebay than purchase new cells to attempt a repair.
Posted on Nov 17, 2014
Pyrhyc
  • 2028 Answers
SOURCE: lap top will not power on
There are a few things that can cause this. Start by removing the battery and starting on AC only. Then remove the memory and try each chip separately. If these aren't the problem, then I'm afraid the power management system or another component on the motherboard may have failed. You will need to take it in for a professional diagnostics.
Posted on Jul 29, 2008
  • 45 Answers
SOURCE: fan on cpu not working.
Best Buy - Geek Squad
http://www.geeksquad.com/services/computer/default.aspx
Posted on Dec 30, 2008
  • 121 Answers
SOURCE: I installed a new 12-cell battery yesterday and
try unplugging the battery and starting up with just the cord if that works charge the battery for 16 hours for a initial charge if after the 16 hour charge it does not work call the company because you have a bad battery
Posted on Dec 02, 2009
  • 16 Answers
SOURCE: Purchased a new Dell Inspiron 6000 (9 cell) battery
Have a look in your power properties and see the settings.They may be set at when battery reaches 30% The computer shutsdown. You can change the settings to your own preferance.
Posted on Mar 15, 2010
  • 3 Answers
SOURCE: HOW DO I INSERT A CD/? not a lap top
the Acer Aspire One doesn't have a CD drive.
Posted on May 09, 2011
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Why red charge light keeps blinking?
Is your battery a LiPo (Lithium?) If so ... These special batteries are charged by a computer circuit that holds the charge amperage constant and adjust upward the charging voltage until the required battery voltage is reached. At this time the charger hold a constant voltage and decreases the amperage as the battery capacity is "topped off". the charger circuit charges the entire battery at once but monitors each cell (cells are about 3.7 volts each) and controls the charge so that all the cells are ballanced.
When one of the cells that makes up the battery starts to go bad, the ballance circuitry prevents over charging the others, so one weak cell hold all the cells back from full charge and better charger circuits will signal you with an led or such that the battery is' going' bad.
May 07, 2014 | Radio Shack Accurian LMD-5108A Portable...
Lap top will not charge battery
Sounds like the charging circuit on your motherboard is defective. Also check the AC adaptror by switching it with other Vostro.
Jan 30, 2012 | Dell Vostro 1014 Laptop Computer (Intel...
I was having trouble with the "low battery"
If you used a voltage 3 times the required voltage then you have probably damaged the camera beyond repair. There may be a protection fuse on the circuit board inside but locating and fixing this would require an experienced electronics technician. i wouldn't hold out too much hope of getting this camera repaired.
May 24, 2011 | Samsung Digimax A7 Digital Camera
I have nokia 6120c charging shows but not store on battery even i changed new battery please help!
You will need to check your adapter and also the voltage that comes to the battery at the charging terminals while the adapter is plugged on.
Since your new batteries are also not charging it is possible there is fault in the charger for not providing the sufficient voltage/current to the battery.
Finally it is possible that there are errors in the main board - charging circuit that prevents the desired levels of voltage required for charging.
Feb 04, 2011 | Nokia 6120
Sir, as i was using my lap top which was in charge ,it got switched off without any intimation.now its not switching on at all.wat could be the problem.the batery light goes off when i connect it to the...
The problem is with your battery.try removing it a while then power it ON..and if it is ON,then battery is not functioning anymore and blocking the voltage requirement.
mastergani
Dec 03, 2010 | Computers & Internet
2001 Pt Cruiser. Car died, ran on battery, low lights. radio fade in and out then died. Replaced Altenator, did the same thing, mechanic said bad battery (battery replaced 2 mos ago) their shop showed bad...
have the alternator bench tested for faulty rectifier diode pack
it may be charging the correct voltage but it is AC voltage and not DC voltage
in which case the battery will die quickly
next to check is the voltage regulator
it has to be 4.5-14.8 volts DC and if it in the ECM unit , will require a new ECM to fix
Aug 26, 2017 | 2001 Chrysler PT Cruiser
Problem with accesing memory card
After you download pictures you must insert card in camera and format the card. See instructions in book.
Oct 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
IBM Power
check the wall plug for power
I have had one where you had to wriggle power fitting in computer (bad plug)
Lap tops are getting cheaper so it could be a viable proposition to upgrade
Any competent local computer shop could transfer files from old computer to new
you could make it a condition of sale
Jul 18, 2008 | IBM (25P3294) Motherboard
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
