Question about Samsung Computers & Internet
How to reset cmos on the motherboard for samsung laptop 500P4C. it is not responding to F2,F4 or even F10
Motherboard BA92-11525B
    Top Expert:
  • Samsung Master
  • 26,692 Answers
If you get writing on the screen, there are no issues with the BIOS. Try a different method.
Posted on Nov 17, 2014
ginko
  • 19396 Answers
SOURCE: jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Posted on Oct 10, 2008
SOURCE: dell studio 1737 laptoplost BIOS password called
BIOS password is NOT able to be Cleared by taking battery out, is stored in NVR. Is impossible to hack, crack, unless get special DELL code. Must contact DELL. provide proof of ownership, a receipt etc, then they will send you special code to enter. OR look for pay For site on internet.
Posted on Apr 04, 2010
  • 180 Answers
SOURCE: Is the cmos battery on a vaio vgn-fe31m on the
Yes the cmos battery is on the motherboard.
Every motherboard that runs a computer has a backup battery to run the circuit while turned off. This battery runs the real-time clock (RTC) and is referred to as the CMOS battery. By keeping the clock active and running even when the computer is switched off, power up/down cycles can be logged and before the internet, your computer could keep dates accurately. It also serves to maintain the system configuration settings in BIOS memory based on RAM or FLASH RAM.
Posted on Jun 24, 2010
alpug
  • 1961 Answers
SOURCE: I have an Asus Eee PC 1005PEB, my "Fn" F3, F4,
the keyboard of your laptop requires cleaning this is a common issue on laptop keyboards.cleaning requires a skilled personnel to do it you need to open and disassemble the laptop to get to the keyboard better bring it at the service center near you.. thanks..
Posted on Oct 19, 2010
  • 102 Answers
SOURCE: HOW THE
FN+ F buttons are used as a shortcut. For example, in my laptop, F1 button has a ? icone at the bottom. when a pres Fn+F1, it will launch the help program. F1 to F12 buttons have different shortcuts.
Posted on Apr 29, 2011
Testimonial: "THANK YOU MUZIKA22 I UNDERSTAND MORE THIS SHORTCUTS F BUTTONS. BUT I HAVE ANOTHER PROBLEM I WILL POST IT :P"
HOW TO REST MOTHERBOARD AFTER CHANGING BATTERY
If you changed the CMOS battery you in effect reset it. On boot up, go into the BIOS setup and check all settings. Even if you don't change any of the BIOS settings, save them as if you did and it will reboot. Should be OK then.
Apr 02, 2015 | Computers & Internet
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
Where do you reset the cmos/bios on a prespa 1 mtherboard by acer aspire 3680 laptop.
For enter bios setup press f2 ,/f4 /f9 or dell.
Now choice fale save mode default.press.F10 for save .
Hope this helps.
Contract for further instruction.
Oct 29, 2011 | Acer Aspire 3680 Laptop
Cant find cmos battery on toshiba satelite l300 motherboard, need to reset hdd password
You cannot reset a HDD password (if its a bitlocker one) and you have lost your encryption key reset file and forgot password.
if you mean the BIOS/Power on password then try this
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 10, 2011 | Toshiba Satellite Pro L300 Notebook
The INTEL Motherboard Logo screen is not passing,,
The key to enter setup should be DELETE or F2.
Jul 23, 2010 | Intel D865GBF Motherboard
Laptop hp nx6320 keyboard f2 key is only working. f1 and f10 key is not responding so that I can't save memory upgradation option nor open the setup.
Have you tried "Delete" to enter the "Bios Settings"? If not this must be the shortcut for your laptop, since most compaqs' Bios settings are accessed with "del" key. Actually for Hp compaq laptops, F1, F2, F10 and Delete keys are the shortcuts. (varies with series/models).
If this doesn't help, try Fn+F1, Fn+F2, Fn+F10 etc..
Good luck.
Thanks for using FixYa.
Jul 01, 2010 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Asus V6J reset cmos button please
The computer should show you a key to hit to enter the setup. Nomally the keys may be F2, F10, DEL, or some other key.
If your computer does not even give you any display, then you can't enter setup--it's failing the POST which means it won't work at all.
In a laptop, you could take it apart far enough to find the CMOS battery and disconnect it to reset the CMOS, but I'm thinking you might have a hardware problem here--like maybe a motherboard.
One thing you can do is unplug it, remove the battery, then reinstall the battery, plug it in and try again. In a laptop, anything further will require dissembling the case.
Dec 19, 2009 | ASUS V6J-X009P Notebook
Cmos
try del f4 f10 f3 f6 f8 f9 tab
Feb 02, 2008 | Compaq Armada 1700 Notebook
Computers & Internet Logo
105 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
