Question about Refrigerators
Fridge light keeps flickering/goes on and off. Does bulb need replacing or could it be an electrical wiring problem?
  • Refrigerators Master
  • 10,291 Answers
It's the door switch. Replacing it will fix the flickering.
Posted on Nov 17, 2014
3 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: Fridge Light - you posted
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Posted on Jan 10, 2009
  • 146 Answers
SOURCE: The light on the fridge side is out and there is a buzzing sound
Try shutting down your unit, unplug it from the wall and wait a few minutes - plus it back in and turn on see if it solves the problem otherwise you may have a faulty board.
Posted on Sep 25, 2009
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
Light in smeg fridge freezer broken
if you replaced three bulbs and same thing happens then it is wiring or electrical.
Nov 29, 2009 | Freezers
Same thing
the flickering lights may be caused by a bad bulb
and/or socket, perhaps the bulb needs to be tightened.
get a different fridge!
Sep 19, 2009 | Refrigerators
Amama Fridge lighting problem
First tighten the bulbs securely. If not loose bulbs you have a loose wire connection.
Aug 14, 2009 | Refrigerators
Headlight flickers or goes out while driving - replaced bulb - same thing. someone said replace a ''power source''??
hi, this is a shorted wire harness. the wire clip that attaches to the back of the bulb has a short in its housing. you will need to replace the headlight wiring harness. this will fix the flickering.
May 18, 2009 | 2001 Dodge Dakota
Fridge lights are buzzing and flickering
You need to replace the electrical control board. It's an easy fix. About $75 for the part. No electrical work necessary. Just unclipping and re-clipping wires into their ports. You do not need a repairman to do this! (I'm a 33 yr. old female, so please forgive my lack of technical terms in the post) I ordered one from AppliancePartsPros.com. It came in two days.
1. Pull out and UNPLUG the fridge.
2. Take out the screws that hold the bottom back panel on
(The electrical contol panel is located inside a white box attached to the lower left corner. )
3. Remove the screws that hold the box in place
5. Remove the bunch of wires out of the clip on the side of the box and pull the box out. Open it by releasing the clips on either side.
6. Disconnect the three sections of wires that plug into the board
7. Remove old board out of the housing
8. Insert new board,
9. Reverse above steps to complete installation.
Note: What triggers the buzzing sound is the door being opened. If you want to stop the sound and prevent the electrical current from going to the fried board until your new one comes, put a piece of tape tightly over the switch that pops out when the door is opened (located inside the unit near the door hinge).
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jan 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light goes out when I start to sew
This may or may not help.. first UNPLUG it..then unscrew the light bulb and look at the base of the bulb socket.. you should see a tang there ( small tab) that makes contact with the bulb.. sometimes that gets compressed to a point that it won't make electrical contact with the bulb or intermittent contact and the bulb flickers.. You may also have a loose wire on the socket terminals too.. Depending on your electrical skil level, you may or may not want to look into repairing that yourself.. Hope this helps..
Oct 11, 2008 | Singer 7462 Mechanical Sewing Machine
Light keep on flicking on and off
Unplug the frig to remove power. Unscrew the bulb. Check the nub on the bottom of the bulb to make sure it is not flattened. Use needle nose pliers to grab the center tab of the bulb socket and pull outward slightly so bulb will make better connection. Could be a faulty switch or bad connection in the wiring.
May 29, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
