Question about Maytag Bravos 6.8 cu. ft. Electric Dryer - MEDB200V
I have a Maytag Bravos dryer. When I emptied the lint trap part of what was on it fell off and now my dryer won't run. I have cleared the vent and hose
The vent hose and the exterior vent are clear of any debris.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
When you say part of what was on it fell off was this lint or a piece of the dryer? If the switch on the door has broken the dryer will not run. In this case you will need to replace the switch / lever.
Posted on Nov 18, 2014
TheMobilian
  • 8220 Answers
SOURCE: My Maytag Bravos washer stopped on the spin cycle
You might have items between tubs. Are you using HE soap in the correct amount?
Service manual
Posted on Oct 29, 2011
TheMobilian
  • 8220 Answers
SOURCE: Maytag bravos washer is making a loud tapping
Their could be something between baskets in the pump. Remove the inner basket and inspect pump.
Bravos service manual and more HERE
Posted on Mar 10, 2011
SOURCE: maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Posted on Dec 31, 2008
SOURCE: F02 Error on Maytag Epic.
I just wanted to confirm stopgo's solution. A few notes/elaborations:
  1. Open the front door of the washer, and run your hand behind the big, gray rubber gasket. You might feel/see small items stuck there.
  2. If you kneel in front of the washer and look along the very bottom edge, you'll see 3 screws in a row. They are of the "torx" type. Unscrew them and then jiggle out the bottom panel. Inside you'll see a large plastic (off-white color) drain, and you can unscrew the 3-inch diameter cap off it and pull it out. The backside of the cap is a filter. Clear it out and put it back in. (We found a baby sock there).
Note also that when you pull out the bottom panel and look inside the cavity of the machine, there is a special manual for service technicians, stuck on the inside wall. I pulled that out -- there were some interesting/helpful information on that sheet telling you how to troubleshoot problems, including checking the drain filter.
Funny that the instructions for checking the drain filter cannot be accessed until you open the bottom panel to check the drain filter!
Posted on Dec 22, 2008
SOURCE: not draining
Where is filter?
Posted on Apr 23, 2008
Maytag Bravos XL MCT will not start, light is stuck on "detecting" under airflow. All vents and lint trap are clear.
If the vent output is clear and lint trap is clear, then there are a couple of more hidden spots that air can get backed up.
First off, unplug the dryer before doing any of this. There's a lot of current to that plug, and getting killed is a really bad way to detect a bad wire or to identify where the heater coil inlet is.
  1. Inlet to the heater area. Laundry rooms have lint in them. All the air that gets blown out the back has to come from somewhere. make sure you don't have a clump o dust bunnies on another section of the rear panel.
  2. The blower motor itself. The lint filter can't get everything. The first time I took the back off my old Kenmore and opened up that area after the lint trap, it was like looking at a chalkboard eraser. Solid lint. The fins in the blower were packed tight with more lint. Cleaned it all out, and it ran better than it had in years.
  3. If the wall/floor connector for the vent hose goes anywhere but straight through the wall to outside, look down the hose and clear what you can, then go outside to the outlet and make sure it's not blocked, jammed, frozen shut, or what have you. Clean what you can from that end too.
    Hope this helps!
Good Luck!
Sep 10, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The dryer is very hot to the touch after only a few minutes in the normal cycle.
inside dryer should be two screws in lint screen holder take out screws the hole piece comes out then you can get farther into the dryer to check for lint is the outside vent clear you could pull dryer vent off run without vent on back to tell if its a venting prom or in the dryer good luck
Apr 05, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Apr 23, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos 6.8 cu. ft. Electric Dryer - MEDB200V Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
