Had bad receptacle caused GFCI on ac window unit to trip fixed receptacle but GFCI wont reset or test do you have to replace cord on ac
Window unit with GFCI ON CORD
  • 9,587 Answers
If the GFCI won't reset , replace it. Make sure you have the new receptacle wired correctly before you do that.
Posted on Nov 17, 2014
Gfci receptacle reset
There should be a reset button on the GFCI. If this keeps tripping, or will not stay in, the receptacle is bad, or there is a ground fault causing it to trip.
Mar 09, 2014 | Porter Cable 5,500 Watt Portable Generator...
This is the solution I rec'd earlier re my De Longhi Pinguino AC 10,000 BTU. If you're in San Diego CA could you make a house call to fix my AC by replacing the cord/plug?\r\n The portion of the plug that...
Never remove a GFI. It is there for a reason. If your plug is has a bad GFI, you can replace the plug with a standard one but make sure you replace where it plugs into with a GFI receptacle which only cost about 30 bucks, or you could replace the breaker that feeds that circuit with a GFI breaker. The problem with replacing the breaker is that if you place any resistance head loads on it (i.e. blow dryer, toaster), it might trip because you get a loss of current from resistance heat. The GFI only looks at what is going in and what is going out. If it sees an imbalance of up to 20 milli amps, it will trip. Your cheapest way is replace with a standard plug and add a GFI plug receptacle to where it plugs into.
Sep 27, 2010 | DeLonghi Heating & Cooling
Exl800 no ac output
I would assume you checked circuit breaker on unit? There should be one over each receptacle (push to reset) and a 2 pole for the twistlok receptacle. Also check to be sure GFCI receptacles aren't tripped. Have you tested the output with a tester? If none of these are the problem , then most likely it is in the generator itself. They do have a 1year warranty (2 year parts)
Jul 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I Kenmore elite upright freezer
This could be caused by any number of things. Could be a grounded compressor. If you remove all leads from compressor and test from terminal to body of compressor with an ohm meter you should get no reading on your meter. ( or a very high meg ohm reading) If the neutral wire from the cord ( usually white) is in any way touching a grounded component then the GFCI will trip. If you have a bad defrost heater going to ground it could trip the GFCI. I assume this unit has ran on this GFCI before? You could buy a GFCI tester, that will tell you if the GFCI is tripping at the desired mA level. A GFCI should trip between 4-6mA. Have you plugged this freezer into a non GFCI receptacle to see if the unit functions?
Jun 30, 2010 | Kenmore Refrigerators
I have a 15 amp air conditioner, with afci plug on a dedicated line, on a 20 amp breaker. Why does it nuisance trip, and not allow me to reset it, is it because of the 20 amp breaker? DRJ
It's definitely not related to the 20 Amp breaker. You do mean GFCI, right? The kind built into the end of the cord on the air conditioner, right? The GFCI is either detecting a ground fault (which means it's doing it's job and there is something wrong with the cord or the unit) or you have a bad GFCI. If the GFCI is in the wall receptacle, that could be a different story.
Jun 24, 2010 | Solar 15 Amp Murray Afci Circuit Breaker
What is wrong when you install a GFI outlet and the green light in the corner goes on than goes right back off than when you try and plug something in the outlet it doesn't have power?
It means that the outlet has tripped. There are one of three problems which you can check. 1. The outlet was wired wrong. On many new GFCI receptacles if the wiring is incorrect the receptacle will trip and not allow you to use it. Proper wiring methods can be found by searching in your search bar "how to wire a gfci". It is possible that what was plugged in went over the amp rating of the GFCI. causing it to trip (note: not as likely as your main circuit breaker would have tripped first). The only other things, which has happened to me a lot is the outlet can be super sensitive to current change. GFCI measure high and quick rises in current. If it is too sensitive to the rise in current the receptacle will trip. In this case it will need replacement, and the store will exchange it for you free of charge.
Jun 11, 2010 | IDEAL 61-534 Digital Breaker Finder W/GFCI
Doesn't operate when plugged in
The test and reset is a GFCI device. They do go bad sometimes. The solution is to cut that plug end off, and install a regular cord end that is capable of handling the rated amperage of the unit. ( I assume this is 120-volt unit)
You should replace the wall receptacle with a GFCI receptacle where the unit is plugged in to prevent electrocution
May 02, 2009 | Heating & Cooling
Flowtron Leaf-Eater Mulcher LE-900F
Shot in the dark here. If the mulcher is tripping and needs to turned off then back on, it's defective and should be replaced. If the circuit breaker in your house panel is tripping, try to use different circuit on a 20 amp circuit breaker. If your using a plug that is controlled by a GFCI receptacle or breaker, move to a different plug. GFCI receptacles tend trip when motor loads are applied. These are my best guesses since I'm not sure what exactly you are reseting.
Apr 25, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
