Looking for power cord for my Sony 5 disc compact disc player model no. cdp-c231
  • Michael Hunter
    Michael Hunter May 06, 2017
    I have the same player and I have the same issue I cannot find a power cord
    New Friend:
    Problem Solver:
  • 13 Answers
The best place to find your replacement power cord is to hunt for one at your local thrift stores , as many of the modern electronics now use a very similar power cord. You may find that if your local thrift store sells power converters , those black plastic ones with an a/c plug at one and ,sometimes the other side of that converter has a power cord that is plugged into that power converter. And if you are not easily ashamed , look down your own alley for people who throw their old electronics away ,. you may luck out and find just the right one.
Posted on May 06, 2017
SOURCE: player reads no disc
make sure you are putting them in correctly
Posted on Jan 27, 2008
SOURCE: SONY CDP-C450Z 5 disc changer.
Yeah
Posted on Feb 13, 2008
welcomejee
  • 10594 Answers
SOURCE: My Power Button is pushed all the way in, can I repair it myself?
Below is an exploded view of Power Switch and board section and I hope will help you to fix power button issue.
2e010a8.jpg.
Power switch board has one screw to open it and you will remount power button and put back in power board in unit.
Posted on Feb 19, 2009
  • 35 Answers
SOURCE: CDP 265 5-disc player
If the disc is actually loading but won't read, try cleaning the laser lens with a cotton swab. Unplug the unit and remove the cover to access the laser. Spray a small amount of glass cleaner on the swab and gently wipe the lens of the laser assembly. Use the other end to dry it and remove excess dust. The only way you can tell if the disc is loading is to remove the top cover and observe if the disc at least loads and spins. If it does, try that procedure.
If the disc doesn't come up to the loaded position and spin (spin the disc by hand to confirm this), your gears may be out of alignment. Take the disc out, and use a screwdriver to manually turn the gear from the bottom of the unit. The gear should be visible through a small hole in the bottom toward the front of the unit. Take a slotted screwdriver and turn it until you see the laser assembly come up to the clamp that holds the disc in place. You may have to force it slightly if the gear has skipped a notch, it might "pop" as it goes past the tooth. Make sure you are turning it in the same direction as it moves when loading a disc! Once you do that, the laser should come up completely and be able to clamp the disc and read it.
Posted on Mar 02, 2009
smarthome2
  • 1114 Answers
SOURCE: disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
Posted on Dec 22, 2009
I need a manual for Sony 5 disc exchange Model # CDP-C245
Sony has the manual for the CDP-C245 on the product support page: https://esupport.sony.com/US/p/model-find.pl?mdl=CDPC245&RECALL=YES&DIRECTOR=DOCS&session_id=3e26e9d1c6457c7bcf37945d8437cecb . Look for the link on the right. I had to click on the link twice. The direct link to the manual is currently https://docs.sony.com/release//CDPC345.PDF . The manual covers three models including the CDP-C245.
I hope this helps.
Oct 30, 2016 | Sony Audio Players & Recorders
Compact Disc Player CDP-CX300 not reading discs
Probably have to get the laser replaced as long as all the mechanics are working to load the disc.
Jan 02, 2013 | Sony CDP-CX300 CD Player
My cdp-455x is showing a loading error after the lazer being cleaned
The laser eimission might have stopped. The laser pickup unit [optical pickup unit] should be replaced.
Apr 17, 2012 | Sony CDP-D11 1U professional compact disc...
My Sony CDP-C910 cycles through CDs, never playing
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
Jul 11, 2010 | Sony CDP-C910 10-Disc CD Changer
Looking for user manual for a Sony model CDP-CX151 100 disc cd player
http://esupport.sony.com/US/perl/model-find.pl?mdl=CDP-CX151&PRODTYPE=33,32,63,71,7,102,26,80,72,44,55,27,74,84,57,61,103,89,10,35,78,48,77,29,50,39,64,58,12,41,81,52,60,73,66,101,45,76,86,62,54,67,70,68,17,2,1,88,100,82,25,28,83,59,69,49,24,104,53,79,42,22,46,13,6,85,36,3,51,9,47,38,4,34,37,43,5
Dec 22, 2009 | Sony CDP-CX151 100-Disc CD Changer
Need instruction manual for sony cd player cdp- c231-
Sony - CDP-C221, CDP-C231 Service Manual
  • Size: 3425.40 Kb;
  • Company: Sony;
  • Description: 1993 US CAN;
  • Model: CDP-C221, CDP-C231 Service Manual;
  • Type: PDF;
  • MD5: 706c4e19e07bc155cc400531fbc7a3ae;
  • Pages quantity: 17;
Apr 17, 2009 | Audio Players & Recorders
2e010a8.jpg.
Feb 19, 2009 | Sony CDP-XE500 CD Player
137 people viewed this question
 Grubhead
Grubhead
