Question about Admiral Washing Machines
My Admiral Mega 22 Plus washer will fill, agitate, spin on the first spin cycle. But, when it gets to the second spin cycle, it will just buzz.
Serial#. 15083222QM Model#. AW20N2V
  • 5 Answers
Try checking the timmer switch.
Posted on Mar 15, 2015
3 Suggested Answers
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
Posted on Aug 04, 2010
derrickbohan
  • 90 Answers
SOURCE: The Knob Stops on spin
its your timer its bad
Posted on Dec 17, 2010
I have a Admiral Capacity Plus washer LNC6267B71. Washer makes loud grinding noise when agitating & spin cycles. Machine does fill, drain, agitate & spin. Only noise is concern.
Hello. Your symptom describes damaged bearings and/or a damaged transmission. This is a MAJOR, INVOLVED repair requiring special tools to prevent serious injury during dis-assembly and re-assembly. I strongly suggest acquiring outside service to repair this machine if cost effective. There are many parts that have to be removed and then replaced--if you've never done this--don't attempt it. There is a brake spring with 200lbs of torque on it that has to have a special tool mounted to relieve the tension during removal and then re-compress it during replacement for example. Sorry to be so dramatic but I don't want you to get hurt needlessly. I hope I helped you!
Nov 05, 2015 | Admiral Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Washing machine buzzes on spin cycle
you probably have a broken belt you hve to lay the washer on its side
Jun 21, 2012 | Admiral AAV7000A
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Mar 03, 2009 | Admiral AW22 Top Load Washer
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Jul 07, 2008 | Admiral AW22 Top Load Washer
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Apr 15, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
