Question about Freezers
Freezer does not work , it was shut down for a year , what can i do ?
Serie number:011020200239
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Is there power going to it??
Can you hear compressor??
Is there refrigerant leaking around the base of the fridge??
Are both fridge/freezer compartments not working??
Can you supply more information on this.
Posted on Dec 01, 2014
    Problem Solver:
  • 23 Answers
Can you provide a little more information? Like what happens when you plug it in?? Nothing? Funny noise?? Motor runs but no cooling occurs?
Posted on Nov 26, 2014
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
I have a kenomore freezer model 19502
In a situation like yours, the freezer comes with a 1 year warranty covering all parts and labor from the manufacturer. On the machine where the model and serial nimber are located there is also a nunmber to call for service. If you can't find the number google the number to whirlpool, who makes kenmore.
Apr 23, 2012 | Kenmore Freezers
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Freezer has difficulty shutting off
Check the relay located on the compressor on the back of the unit. Sounds like the relay is not completely shutting down the compressor. Almost like it is still allowing electrical currents to get to the compressor
Feb 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Is Freezer Motor On The Outs?
The over current protection relay needs to be checked out. Usually it is mounted on the compressor or nearby. Unplug before attempting repair.
Aug 04, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Sides of freezer extremely hot
if there is air getting into the freezer because the door is not sealing properly the unit will run because it is sensing it is not cold enough inside. your unit releses the heat from the refrigerant through copper tubing that runs through the cabinet, and thats why it is hot. you need to level the unit make sure the door is sealing on the top bottom and both sides ansd then the freezer will work properly and be able to shut off after it has come down to the proper temp.
Aug 05, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
