Question about Goodman Heating & Cooling
Why would my goodman gas furnace leak water from the panel that the blower motor is attached to?
  • 739 Answers
The only reason water would come out of your furnace is if you also have your AC in the same system, and the condensation line is not allowing the water to drain properly.
If the water only happens during cooling, clear the condensation line. If it is happening during a heating cycle you may have an improperly connected thermostat, a bad control board, etc...
Posted on Nov 17, 2014
  • 108 Answers
SOURCE: goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Posted on Nov 07, 2008
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 333 Answers
SOURCE: goodman furnace leaking water
Yes you can use regular pvc glue. You should use pvc primer before you glue it.
Posted on Jan 21, 2009
machtcl1
  • 61 Answers
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
Posted on Feb 01, 2009
SOURCE: Water leaking out the bottom of my Furnace
I have a forced air gas furnace and water is leaking from just above the area where the hose is attached. I removed the cover but cannot figure this out. It only leaks (a lot of water) when the furnace is running. Please help asap!!! Tthanks so much, Dianne
Posted on Jan 03, 2010
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Furnace faults out for water blockage in Coil front cover
I think the drain is restricted and not allowing the water to drain fast enough. As the inducer collects water it is normal for the vacuum to increase. Is there a vent on the condensate drain to break the vacuum? If not, add one by cutting in a tee on the drain line as it exits the furnace and put a 4or5" stand pipe above the tee. Is the unit displaying any blinking lights by viewing thru a small window? If so, remove the lower panel and look on the wiring diagram for an error code to give you a starting point where to look. If you are getting a 3 blink error code, what I mentioned above may help. There should be no water leaking into the furnace, you need to figure where the water is coming from and need to stop it.
Dec 11, 2009 | Jandy Lite2 LJ125 Ceramic Gas Heater
Water leaking out bottom of Goodman propanefurnace drain tubes are clear. draining out under the actual furnace
Check the top of the gas flue. Make sure the cap is on it. If not it will allow rain to get inside. If this is only a furnace, this is the only thing it could be. Nothing produces water in a furnace. If it has an A/C coil attached. The condensation drain might be stopped up allowing it to leak.
Oct 13, 2009 | Goodman GMS90703BXA Heater
How to install a new blower motor in a Goodman gas
remove the blower unit it slides out on some gas furnaces you may have a control bord in the way if you dont have a goodman motor you will need a belly band to clamp to new motor to provide the mounting arms also after loosening the shaft set screw spray w wd40 turn on side and shake motor should fall out if gas furn 115v motor hope this helps
Jun 09, 2009 | Heating & Cooling
Goodman furnace leaking water
Jan 21, 2009 | Goodman GMS90703BXA Heater
Furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Nov 23, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
293 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
