Question about HP LaserJet 5 Printer
HOW DO I INCREASE THE DISPLAY'S BRIGHTNESS ON A HP LASERJET 5 PRINTER?
    New Friend:
    Problem Solver:
  • 6 Answers
There is no way to change the brightness on this model
Posted on Nov 20, 2014
    Habit-Forming:
  • 91 Answers
You have to clean lenses and mirror ( inside the scan unit , the scan unit is the black unit in the top of printer - under top cover-and its covered by metal plate
Posted on Nov 17, 2014
joelmar
  • 96 Answers
SOURCE: hp laserjet printer problem
Try to reinstall your software, if it is show the error again replaced the memory and then try to power on the printer.
Posted on Jun 16, 2008
  • 141 Answers
SOURCE: to install a 500 sheet paper tray for hp laserjet 5 printer
make sure you reboot the printer after doing so or the printer will not recognize the new tray 3 assembly.
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: HP Printer Color LaserJet 2840
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
Posted on Jan 01, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
  • 99 Answers
SOURCE: hp 2420n printer having no display
i have the answer
mail me printerman007 at gmail.com
Posted on Mar 13, 2010
Screen not bright auto-brighness not working
To increase the brightness, either swipe up from the bottom to get the control panel, and increase the brightness there (slide the slider just below the 5 circles to the right) or go into Settings > Display and Brightness> Increase brightness using slider. You can also turn on the auto brightness from here if it is off, or turn it off if it is not working like you want it to.
May 13, 2016 | Apple iPhone Cell Phones
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
I cannot increase scree brightness of my HP PROBOOK 4440s Also tried by getting in to power option in control pannel and moved the slider... even then there is no change in brightness
Go to the system tray in the lower right bottom of your screen and click on the "plug and battery" icon. Left click on it and you will see a link to "Adjust Brightness" towards the bottom of the menu.
AND ALSO Go to control panel. choose display. Click on "adjust brightness". You find " Select a power plan". You can increase brightness at the bottom of the screen. it's work for me.
Feb 23, 2015 | HP 4440s Probook
How do I increase the display brightness
If you have an older model laserjet there is no adjustment for the display brightness. Either there is dirt on the inside of the display which can be fixed by taking the control panel apart, or the display is failing.
Nov 16, 2014 | HP LaserJet 5 Printer
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
My printer is HP laser jet M1522nf series. It rotates inside while switching on but no display comes.
Formatter faulty,
Symptoms: No display, not recognized by system,if network cable connected to the port data transferring LED are wont glow or low brightness,
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have HP 3055 all in one printer, display is not working please give me a solution
Someone may have turned the brightness down on the display. Keep the printer unplugged for awhile to clear the ram. Plug it back in and see if the display comes back.
The screens on the HP 3055's tend to go out a lot quicker than other HP printers. It may need to be replaced. HP will be able to price this for you.
Mar 03, 2011 | HP LaserJet 3055 All-In-One Printer
Laptop Lcd display problem
hi,
try use the
fn+ -> (right arrow)
fn + <-(left arrow key)
to reduce or increase the brightness, if it doesn't help call hp
Further Queries are welcome
Feb 18, 2009 | HP Pavilion dv9000z Notebook
Dark Background on HP Laserjet 4100
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Jun 18, 2008 | HP LaserJet 4100 Printer
HP LaserJet 5 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
