I have a laptop SONY: MODEL: PCG-FX802 (FR) My computer will not turn on, the power sector and the battery are in good condition. The problem,: I clean the screen with a vacuum cleaner for computer w
I have a laptop SONY: MODEL: PCG-FX802 (FR) My computer will not turn on, the power sector and the battery are in good condition. The problem,: I clean the screen with a vacuum cleaner for computer work, I am looking for a solution to power my machine. A big thank you for your help.
  • Computers & ... Master
  • 9,639 Answers
When the coin cell battery in the laptop is expended, the laptop won't start. Replace the coin cell battery and then you'll be able to boot the laptop again.
Posted on Nov 17, 2014
Testimonial: "I find the battery is inside the laptop, I replaced the battery with another, but the computer will not turn on, a big thank you to tell me another solution"
  • Lawrence Oravetz Nov 19, 2014
    It is possible that the flat ribbon cable that comes from the power button has lost connection where it connects to the motherboard. The connector is delicate. gently release the lockdoen bar on the connector and pull the cable out of the connector. Re-insert the cable squarely in the connector and reengage the lockdown bar. If this doesn't produce results, then there is another possibility that static electricity generated by the vacuum cleaner has damaged a component on the motherboard. If the PC is still under warranty, contact their service department for instructions on how to get it repaired.
  • Kamel KHEROUFI
    Kamel KHEROUFI Nov 19, 2014
    I find the flat cable that comes from the power switch on the motherboard. I have. Gently release the lockdoen bar on the connector and I remove the cable from the connector. I Re-insert the cable firmly into the connector and I re-engage the locking bar. maisi this does not give results Looking located the BIOS on the motherboard THANK YOU
  • 3 Answers
SOURCE: Sony Vaio PCG-K86P laptop
fjhdsjafjkds
Posted on Jan 02, 2008
Benimur
  • 6966 Answers
SOURCE: Laptop Driver PCG-8N1M
Due to regional differences of the models, some model numbers may only be applicable to certain limited regions, could you pls try and verify if your PCG-8N1M is identical to the PCG-GRT895MP. If yes, you may want to try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 26, 2008
Pyrhyc
  • 2028 Answers
SOURCE: sony pcg 5l1m laptop wont start
This could be a hardware problem, and this machine only being two weeks old shouldn't have any problems. I'm going to recommend you take it back for exchange.
Posted on Aug 28, 2008
cheap to fix
  • 404 Answers
SOURCE: Sony Vaio Laptop Model PCG-384L - Won't turn on.
it means time to buy a new battery..it happens
Posted on Mar 09, 2009
  • 5 Answers
SOURCE: sony laptop driver model PCG-7G2L
http://b2b.sony.com/b2bMicrosites/landingpage/vaio_drivers/download_vaio_drivers.html
you can download from this web site
Posted on Apr 01, 2009
I have a laptop SONY: MODEL: PCG-FX802 (FR) My computer will not turn on, the power sector and the battery are in good condition. The problem,: I clean the screen with a vacuum cleaner for computer work,...
Have you plugged in your computer to an adapter and does your battery charge? If the battery is empty due to the adapter not functioning properly (You can get the adapter checked out most likely free at a local micro-center) then getting a universal adapter might be needed to turn on the computer.
When was the last time your computer turned on, and if you can turn it on again, try to note the power levels of the battery, whether it is charging or not and whether there are any errors to cause the computer to crash (could appear to not turn on due to power but could be a dead hard-drive, etc)
Nov 16, 2014 | Computers & Internet
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
I need sony laptop drivers model PCG-6P9P
to the one who needs a sony vaio laptop driver,
i hav a sony vaio laptop model PCG-6P9P. evrything is in good condition except the battery and keyboard. how much do you want to pay for my laptop?
09228929023
Sep 13, 2010 | Acer EZDock (LC.D0303.005) Docking...
How can I adjust me laptop's brightness?
You really cannot adjust screen brightness through windows unless you have calibration software that uses a light detecting frame... I had a Sony Vaio PCG-something and Vista really screwed it up as well. Here's the Sony eSupport website where you can enter your model and reinstall some originals drivers for the computer that may restore functionality to your function keys:
http://esupport.sony.com/perl/swu-download.pl?upd_id=2207&SMB=YES
Some things you can do to save battery power: turn of your wireless if you're not using it (there's usually a wifi switch on most laptops, turn it off), set your screen saver to come on as quickly as possible, run as few programs as possible and try to avoid graphic-intense programs.
May 24, 2008 | Sony VAIO PCG-Z1WAMP1 Notebook
Computers & Internet Logo
David Payne
David Payne
