Question about Epson Office Equipment & Supplies
The error reads turn off power check and clear paper jam reattach any parts you may have removed turn off power. I have removed all paper jams
    Habit-Forming:
  • 91 Answers
The is a sensor in paper path not returned to the home position after removing jams
Posted on Nov 17, 2014
  • kipio Nov 18, 2014
    All greek to me where is the sensor path and what do I do
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
frcs68
  • 1605 Answers
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
BurntLime
  • 8 Answers
SOURCE: Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
Posted on Jan 05, 2009
  • 13433 Answers
SOURCE: Canon MP140 paper jam error with no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Carriage jam message...........comes on no matter what.........reset several times
Solution one: Turn the All-in-One off and on again Turning the product off and then on again might resolve the issue. Step one: Turn the All-in-One off and on again
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 60 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product
Step two: Print a self-test report
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01461502.gif ). The Setup menu opens.
  3. Press the arrow button to select Tools , and then press OK .
  4. Press the arrow button to select Self-Test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any jammed paper Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Use the following steps to check for and remove jammed paper from the rear of the HP product.
  2. Disconnect the USB cable from the rear of the product.
  3. Disconnect the power cord from the rear of the product.
  4. Squeeze the tab on the rear access door to release it, and then pull the door outward to remove it from the product Figure 1: Open the rear access door
  5. Gently remove any jammed paper from the rollers inside the product. CAUTION: If the paper tears while removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. Reattach the rear access door. Gently push the door forward until it snaps into place.
Jun 21, 2011 | HP Photosmart C5280 Printer
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
A single sheet of paper has jamed, can not release it.
Clearing a paper jam
If the paper jams in the printer, follow the steps below to clear the jam:
Remove the paper stack from both paper trays.
Press the POWER button. Instead of turning off, the printer will try to eject the jammed sheet.
If the printer cannot eject the paper, unplug the power cord from the back of the printer.
NOTE: Do not press the POWER button again before unplugging the power cord.
Open the rear access door at the back of the printer. To do this, press the handle to the right and then pull out the door.
Remove the jammed paper. Make sure no small pieces or obstructions remain.
Reattach the rear access door and plug the power cord back into the printer.
The printer will turn on automatically and be ready for printing again.
Reload the paper in the IN tray.
Try printing again.
Nov 25, 2010 | HP LaserJet 1010 Printer
I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
  5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
  6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
  7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
  8. Remove any jammed paper from inside the duplexer.
  9. Close the duplexer cover.
  10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
  11. Reconnect the power cord to the rear of the product.
  12. Plug the power cord back into the wall outlet.
  13. Press the Power button (c01602202.gif ) to turn on the product.
Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
  1. Load unused, plain white paper in the input tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01726396.gif ).
  4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
  5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Are there any releases for a paper jam in an HP psc 950? I have a paper jam that is under parts that do not appear to be moveable. I also cannot remove the paper tray--and my fingers can't fit inside to...
1) Power Off.
2) Disconnect USB cable and power cord
3) Clear the paper jam from the back of the unit by opening the rear access door. Turn the dial on the rear access door counter clockwise, and then pull the door toward you to remove it
4) Gently remove any paper from the rollers. Get all the pieces - any bits left inside will make it more likely to jam with future use
5) Reattach the rear access door. Gently push the door forward until it snaps into place
6) Reconnect the cables and power cord.
Try your print job again.
Dec 21, 2009 | HP PSC 950 All-In-One InkJet Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
