How to play record without needle sounding scratching
  • Audio Player... Master
  • 5,455 Answers
If the stylus (not needle) is good then you might have got an incorrect earth wire connection on the cartridge or a bad connection to it. Also check the plugs and wiring between it and the amp. The earth connection might be broken there.
Posted on Nov 25, 2014
3 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: ** sound
First and foremost, make sure you plug into directly to the PHONO input of your receiver. If your unit does not have a PHONO input, then you wont be able to hear much coming from the unit. The PHONO input is a pre-amplified input, and this turntable requires an amplified input in order to transmit it's signal correctly. Just using an AUX or LINE IN will not have enough power to increase the signal of the turntable. You have the option of purchasing a PHONO PRE-AMPLIFIER (range in price from US$15-30), or purchasing a new receiver with a PHONO INPUT!
If you have it connected to your phono input, and still no sound, your turntable may have either faulty RCA cables (red/white cables), or a bad tonearm - in either case will need to be replaced.
Hope this helps.
- DJ PRO AUDIO
www.DJPROLAB.com
Posted on Mar 21, 2008
dunnbiker
  • 8546 Answers
SOURCE: Well im not too sure if my needle is broken but
It's called a stylus. What red or white caps are we talking about? Some phono cartridges come with stylus guards that flip up out of the way for play or down to protect the stylus from damage while in storage or during tonearm balancing. The stylus needs to touch the record groove directly.
Posted on Jul 22, 2010
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
On a L-A55, what causes the arm to retract not high enough and cause the needle to scratch across the record?
I think you you mean the lift and there is are screw on it , and a feather on the other side, turn the screw to the the right a bit , so it gets a little lower
Oct 16, 2014 | Audio Players & Recorders
Needle stylus unit rubbing the record.
There's too much weight on the stylus or the needle is not inserted correctly.
May 15, 2017 | Office Equipment & Supplies
Tone arm not lifting when record is over
Hello Caufield,
Ideas... Yes, indeed,
But without a MAKE or MODEL they focus
a lot on ESP & other psychic capabilities...
(Mind reading: The lack thereof)... Sorry...!!
In ye olden daze...
when I was young the (stacked record CHANGERS &
simple turn table) TONE arms were largely Rube
Goldberg
electro-mechanical thingy-ma-call-it...
that triggered off of the wag action of the center grooves ...
(in all 78, 45 and 33 rpm records (once upon a time)).
Rube Goldberg Wikipedia
Without BENEFIT of year, make or model... ONE
might ACTUALLY look at the mechanical MECHANISM
and SEE the broken or missing spring, link or cam...
The very first/last action of ARM CONTROL was
the lift/lay action of the tone arm..
Without that FUNCTION "working" you are just
ruining records & needles...
My best advice would be to REPOST with
a hint of the proper nomenclature... I'm pretty sure
an appropriate volunteer expert will step forward.
Try it... you will like it and it is still totally FREE
Carnac the Magnificent
Aug 07, 2017 | Audio Players & Recorders
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
I have a sony PS-LX33 turntable. When I try to play the record, the needle gets stuck in one position and will not move across the record. I have fitted a new stylus but still does not work. Can you help...
First check that you can move the arm right across the turntable platter. Do this without a record to avoid scratching it. If you can take it to the middle at the same height as a record then no mechanical fault is present.
That being OK it perhaps means that too much weight is being applied to the stylus. You can adjust it with the weight at the end of the arm. It should have numbers on, try it on 1 or 2 to start with - playing a record. The idea being to get the pressure just right without making it jump out of the groove or too heavy giving a rumble sound. It's a question of trial and error.
Sep 07, 2011 | Sony Audio Players & Recorders
Well im not too sure if my needle is broken but when i play a record i cannot hear sound and it sounds like my record is being scratched. Do i need to keep the white cap on the needle or not? or is it just...
Jul 14, 2010 | Numark ttUSB Turntable
While playing A cd the sound intermittenly stops like A skip and sound comes back but player is never moved
If the CD is the problem it could be scratched or dirty, clean the CD with a CD Cleaner if need be. If the CD mechanism is the problem the sled assembly may not be moving smoothly or is hindered ( the sled mech moves the laser across the CD like a needle arm move the needle across a record), the laser lens may be dirty also. Use a CD lens cleaner to clean the lens if you can not manually clean it with some lens cleaner and a swab. If the sled mechnism is the problem the unit may need to be taken in for service.
Jun 27, 2010 | Durabrand CD Player with Cassette...
The speakers are so scratchy sounding, even without playing a record on it. Just received it as a gift, so bummed!
static noise coming from the needle. reomve the needle and the speakers should go silent. if this works replace the needle
Feb 20, 2010 | Crosley Traveler Turntable
43 people viewed this question
 Grubhead
Grubhead
