Question about Garden
How do you find an inline fuse for a mtd 38inch 14hp riding mower the model number is d01338cn. i hope that is it the tag is very very faded
The model number is d01338cn. i hope that is it. the tag is very very faded
    Problem Solver:
  • 12 Answers
Trace positive wire from battery to solenoid and then to ignition switch fuse should in between
Posted on Nov 19, 2014
  • 391 Answers
SOURCE: MTD 12.5 HP Ride On Mower won't stay running
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
Posted on May 26, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 2841 Answers
SOURCE: mtd riding mower: right mower blade cutting
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Posted on Sep 18, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
  • 57 Answers
SOURCE: My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Posted on Apr 04, 2012
Testimonial: "I finally got it started after draining the gasoline out and replacing with new gas. It only runs with the choke engaged, but I'm going to seafoam the carburetor and add it to the gasoline."
How can I find a manual for my MTD mow master 11hp ride on mower, model number 1333A
Try mtd website. Usually the real model number is longer than that...check the tag on the mower for another number.
Jul 17, 2016 | Mtd Garden
I need a manual
Try Goggle it. owner's manal mtd-----------
Jul 05, 2015 | Mtd Garden
How do you find an inline fuse for a mtd brand riding mower 38inch cut 14 horsepower?
Lift the hood and it should be close to the front side that you are now looking into. Look for the new flat colored fuses not he round old style fuses.
Nov 16, 2014 | Mtd Garden
How do I find an inline fuse for a mtd ranch king 38inch 14hp riding mower
it should be under the cover right between your legs when you are sitting on the mower
Nov 15, 2014 | Garden
How do I find an inline fuss on a mtd ranch king 38 in 14hp riding mower8
Lift your hood and look around where your ignition is. Not sure on this model but that's where I would start. Some are regular car type fuses plugged into the wire. Sometimes there is a fuse block with multiple fuses like on a Toro. You should see it around there though. Good luck.
Nov 15, 2014 | Mtd Garden
Were is the model number located on a 14hp 42" mower deck?
The model number for your mower should be under the seat on a tag that has the model number and serial number of your machine.
Jul 21, 2011 | Mtd Drive Belt 42"
Require a spindle for mastercraft riding lawnmower
This is a MTD brand mower, most mower shops stock these spindles, sometimes in a less expensive after-market version, take your local mower shop that model Number and they should be able to get your new spindle
Jul 04, 2010 | Garden
Ride on mower
Jackie
MTD Part number 754-04001A is the LOWER drive belt
MTD Part number 754-04002 is the UPPER drive belt
MTD Part number 754-0329A is the BLADE drive belt
They do not list them by size, only by part number because they are specially made for lawn mower use and generally not a "common" size
Oct 12, 2009 | Garden
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
