How do i cause my casio fx-911w calculator to display with commas?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Sorry, but this calculator does not have that capability.
Posted on Nov 17, 2014
SOURCE: Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Posted on Apr 28, 2009
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Posted on Jun 29, 2009
  • 7993 Answers
SOURCE: how do i calculate permutation in fx-82ms casio
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
Posted on Sep 06, 2009
  • 7993 Answers
SOURCE: how to calculate inverse of a 3x3 matrix in casio
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers.
Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
Posted on Sep 07, 2009
  • 7993 Answers
SOURCE: How do i calculate antilog
For common logs (logs in base 10) use the 10^x function : Press [SHIFT] [Log] to access it.
For natural logs, use the exponential function. Press [SHIFT][ln] to access it.
Posted on Dec 03, 2010
Sorry, you can't. The calculator simply does not have that capability.
Nov 16, 2014 | Office Equipment & Supplies
I have just changed from using a Casio fx-83MS to a fx-83GT Plus. Is there a way of displaying a comma between every third whole number?
I do not think that Casio scientific calculators have the possibility to separate thousands, millions etc. The Sharp have that feature.
Sep 15, 2013 | Casio Office Equipment & Supplies
Display comma placeholder
The Casio Fx300ES does not provide comma or other separation/ spacing symbol to separate thousands.
Sep 26, 2012 | Casio fx-300ES Calculator
Fx-570 ES how can i get comma is the results for example 100,000,000. Comma after every three digits?
Sorry but you cannot. You can change the decimal mark from dot to comma but you cannot have the calculator separate the digits between thousands (thousands separator).
Jan 24, 2012 | Casio FX570ES Scientific Calculator
Fx-82es how we seperate digits with the help of comma. like 123,456,789. Is the comma sepration option is available in Fx 82es?
Yes,it's possible to program the Fx-82es to separate the digits with the help of comma.
PLEASE FOLLOW THE INSTRUCTION CAREFULLY.
If you make a mistake then please turn the calculator off and start over again.
Turn the calculator on.
GO TO Display setup screen
Disp 1
You will has two options
1 for DOT (that's not what you want)
2 for Comma (please press 2 and enter/triangle pointing to the right)
Please let me know are you able to get to setup mode and make the comma change on reply.
Jan 24, 2011 | Casio FX-300MS Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
MY CASIO CALCULATOR MODEL NO IS FX-911W IT'S TWO SWITCH IS NOT WORK PROPERLY THAT IS AC & C & ALL OTHER ARE WORK PROPERLY
How to turn off fx-911w? I tried shift and on. Shift and AC does not work also. Please help thanks
Aug 10, 2010 | Casio FX-115ES Scientific Calculator
Can i calculate calculus using fx-991ms
If you want to get an answer like 1/2X for d/dx(X^2), you will have to purchase a CAS calculator like Casio's Algebra FX-2 or Classpad. TI series calculators also have CAS.
However, you can calculate the numerical values of derivatives and integrals only.
To calculate the value of a proper integral:
  1. Press the 'ON' key;
  2. Press the Integral key b8325f5.jpg;
  3. Enter your expression (example X^2+X-3 etc);
  4. Press the 'comma' key after your expression;
  5. Input the first limit after comma, input comma again after first limit;
  6. Close brackets;
  7. Press the equals key, display may return after a while with the answer.
for eg to calculate xdx from 0 to 2, input as follows:
dx(X,0,2)
To calculate derivative at a point:
  1. Press Shift and then the integration key.
  2. Enter your function;
  3. Input comma;
  4. input the point at which you want to evaluate the derivative;
  5. Close bracket and press enter.
Example, to calculate d/dx X^2 at 3 input:
SHIFT+dx key X^2,3)
Display looks like this: d/dx(X^2,3).
Oct 23, 2009 | Casio FX-300MS Calculator
jasbo
jasbo
