Question about Nordic Track C2255 Console (treadmill)
How do I dismantle a Nordictrack C2255? We need to move and it won't fit through the door.
We are moving and we can't get it through the door. Please give me advice how to dismantle it...
5 Suggested Answers
  • 34 Answers
SOURCE: Need to disassemble NordicTrack X7i trainer to
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Posted on Aug 10, 2010
SOURCE: Please help for how to
The best way is to detach the two upright posts that hold up the console from the frame. You will also have to unplug the wiring harness inside one of those uprights. Once you have done that, you can move the machine in just two pieces. If you have any questions, feel free to contact our Customer Service Department @ service@iconfitness.com
Chase NordicTrack Social Media
Posted on Dec 16, 2010
ercupa190
  • 12223 Answers
SOURCE: My nordictrack 1000 turns on, but the track does not move?
1) Check the sensor reed switch see the diagram by 1/8"
2) use the calibration software for easy diagnostic and fix it. see your owner manual and go under the hood for instruction step.
3) exchange the battery by new ones for console.
4) Measure the input 115vac for motor without load
5 Test the main motor board for output +5vdc for Display board.
See the block diagram for easy diagnostic that I did designed for quicly adjusting and fix it.
Sincerely Merry Christmas,.
ernesto cuadra
managua, nicaragua. c.a
12_24_2011_6_16_18_pm.gif12_24_2011_6_16_37_pm.gifhttp://www.fixya.com/support/r10786838-test_procedure_dc_motor
see my tips
Posted on Dec 24, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Posted on Nov 19, 2012
Hi, I have a NordicTrack c900i that I'm moving from one room to another in my home. What can be done to make this fit without harming the treadmill please? Would we remove the "legs", or what and how
can you place a blanket on the floor and tip the unit on it's side and put one end through the door followed by the rest slide it through on the blanket
Feb 07, 2016 | NordicTrack Exercise & Fitness
Nordictrack c2255
Hi
I have Nordictrack c2255 having software issue. Display is showing upside down and I think it needs to be reprogram
Mar 28, 2014 | Nordic Track C2255 Console (treadmill)
My NordicTrack X7i cannot locate my computer IP address
Reset the treadmills and try again. Follow the section troubleshooting owner manual. or download from www.fitness.manualsonline.com
GO TO http://whatismyipaddress.com/ip-lookup and test again
God bless you
Oct 14, 2013 | Nordic Track C2255 Console (treadmill)
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
My C2255 Nordictrack has been fine for the past couple of years until recently when it started turning off intermittently with no power to the console. Now, the console will not turn on at all. The...
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Oct 17, 2011 | Nordic Track C2255 Console (treadmill)
Please help for how to disassemble a NordicTrack EXP2000 treadmead for moving. Thanks.
Dec 15, 2010 | Nordic Track NordicTrack Treadmill, A2550
Cant fit it through the door to move to another room.
Only 3 choices:
1 - leave it in place
2 - Take it partially apart so it will fit through the door
3 - Widen the door frame.
Since the treadmill got into the room, it should be able to get out. Most likely #2 is the option for you.
Dec 07, 2010 | Nordic Track NordicTrack A2550 PRO...
Nordic Track C2255 Console (treadmill) Logo
393 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
