Question about Cuisinart CBT-500 SmartPower Premier Work Top Blender
<!-- from fixya rte -->Need gasket for blender 2.5" diameter - Cuisinart CBT-500 SmartPower Premier Work Top Blender
Need gasket for Aroma blender model ABD-530RG.
I found my blender gasket on Amazon. Contacting the manufacturer may work as well. You'll need the manufacture's name and model number of the unit to get started.
Amazon com Online Shopping for Electronics Apparel Computers Books DVDs...
Mar 24, 2016 | Blenders
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
-Colleen@MendingShed
Apr 02, 2015 | Krups 572 Power Xtreme VI Work Top Blender
Want a seal for kenwood blender model bl300
That kenwood is a UK model so if your in the US it's tough to source. The ring you need should have an outside diameter of 76 mm and an inside diamete of 56 mm.
This is a uk ebay link with the exact part.
1 Kenwood BL300 Blender Liquidiser Rubber Seal Gasket
This is a us amazon link with something that might work but not exact. There is a uk amazon equivalent if that works better for you.
Amazon com kenwood blender seal
Feb 18, 2015 | Kenwood Blenders
Sunbeam 2774 Blender Logo Problem with the Sunbeam 2774 Blender I need a gasket for my sunbeam blender #2774.
The gasket is not available by itself, you need the blade assembly part number 123250-000-000 available from Sunbeam at 1-800-458-8407.
Aug 13, 2011 | Sunbeam 2774 Blender
Need a replacement gasket for the Cook power blender
Boy, I spent some time on this and - so far as finding an exact replacement on the Internet - I'm stumped.
But I'll tell you what I'd do, in your position.
I'd take the old worn (or split) gasket to Ace Hardware or True Value, and ask someone to match it up for you. Really, a gasket is a gasket. It's just a matter of the size, the thickness, and the "compressability" of the rubber (obviously, you'll want a soft rubber gasket). If you find one, you may want to buy two of them... just in case.
If this doesn't work, then get a square piece of rubber gasket material (Ace, True Value, Home Depot, etc.). You can either cut one yourself (use cups, jars, measuring spoons that are the right diameters to draw your two ring patterns), using an Exacto knife to carefully cut them out.
If you don't want to do this yourself, ask someone who's handy & who has a steady hand to do it for you. You can pay them with a freshly made smoothie.
Mar 03, 2011 | Cook's Essentials Smoothie Maker Work Top...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Leaking blender
It could be the gasket, could definitely be that crack in the collar, and even possibly the blade assembly - here is the official website to get all of those parts:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4154&linkon=subsection&linkid=112&secid=53
-Tha Mp3 Doctor
Mar 31, 2009 | Back to Basics 600 Smoothie Elite Work Top...
I followed the link to purchase a rubber gasket for my blender. The item is $2, weighs less than an ounce, but the shipping charges are over $10 from Utah to California. Something wrong here.
I called the place.. and the lady sold me 2 Gaskets.. for $2 and only charged me $4 for shipping.. Much better rate.. We love our smoothie machine.. but when you cant find decent replacement parts.. its really dis-heartning.
Jan 09, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Cuisinart CBT-500 SmartPower Premier Work Top Blender Logo
46 people viewed this question
Top Cuisinart Blenders Experts
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
