Question about Garden
Water leaking from pump 1500 psi Hausfeld Campbell pressure washer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
If you have your model # then you can find parts at this web site.
http://www.ppe-pressure-washer-parts.com
Posted on Nov 25, 2014
5 Suggested Answers
  • 770 Answers
SOURCE: My 1750 psi campbell hausfeld pressure washer will
Common with that washer...it has a wabble pump. Release the trigger, if by pass does not engage, stalls engine. You can however keep using it, all you have to do is keep trigger pressed, and when you are cranking engine, depress trigger with the free hand. Can be repaired, but the fix probably will cost more than a new pump.
Posted on Oct 19, 2009
  • 251 Answers
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Posted on Nov 19, 2009
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
SOURCE: i have a 2300 psi
If you no longer have High Pressure coming out while machine is running, it's a pump issue.
Posted on Mar 19, 2011
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
May 04, 2015 | Campbell Hausfeld Garden
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
I have a 3000 psi campbell hausfeld gas pressure washer and it has no pressue how can i fix it
Small stream sounds like your pump is not working at all - you are getting house pressure only. First check the intake fitting where you attach the hose for debris that may be clogging the water flow. Same for the pressure hose and quick connect fittings. Remove the tip from the wand and see how much flow you get. If it's still only a small amount, with the motor running, you probably have a bad pump. This can be caused by bad seals inside the pump, or by running the motor without maintaining water supply to the pump, which can melt the seals or even seize the pump if allowed for too long. Repairing the pump is typically more work and expense than replacing it, assuming you can locate a replacement pump.
Aug 03, 2014 | Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
I have a Campbell Hausfeld RBPW1810 pressure washer, It has two detergent tanks. I cann't get either to work. I just purchased the unit in June if this year and this is the frist time I am useing the unit....
Sometimes thinning the solution will help, but in any case make sure the line from detergent tank to pump is sealed, otherwise it just sucks air. I use a small hose clamp at pump. let us know
Sep 22, 2010 | Campbell Hausfeld 1800 PSI Electric...
Gun
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
