Question about Radio Communications
Nokia Lumia 635 isnt pairing to my Panasonic m25 Bluetooth headset device
SOURCE: Bluetooth headset Nokia BH-600
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
Posted on Jan 14, 2009
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Posted on Feb 20, 2009
SOURCE: My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
Posted on Aug 05, 2009
SOURCE: Emerson em227 wont pair
With your phone closed press and hold the center button on the bluetooth until it starts blinking blue and red the open your phone and go to blue tooth> ad new device> then it will go to pairing then auto pairing and that should do it
Posted on Sep 14, 2009
  • 4 Answers
SOURCE: trying to pair nokia x6 with nokia BH-214
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
Reply
Posted on Sep 17, 2010
How to pair Plantronics m25 to iphone4s
Go to the website and download the manual to learn how to put the headset in "pairing" mode: Plantronics M25
Nov 28, 2014 | Plantronics M2500 Consumer Headset
How do I transfer pictures from Nokia Lumia 928 to laptop
You can transfer photos from your nokia lumia 928 to laptop wirelessly or wired. Wired transfer is the easiest way when your unit comes with the data cable and the software. Now, if the software is not inclusive you can set your CP's connection settings "Connected as USB memory" however you may have difficulties in viewing since the connection layer platform is not capable of viewing the pictures or images but you can view later after you copied it on your laptop. Now, if your unit doesn't come with data cable and software you can use the BLUETOOTH connection by simply turning or enabling both Bluetooth device on your laptop and cp which can be found in settings usually, once enabled and set visible you will noticed both devices sees each other with their name if not try to search manually by pressing search and chose paired bluetooth device with confirmed access code or id. Right then, when connection is successful you can start copying pics or images to your laptop. (Make sure you know the directory your pics are being copied, it is usually saved in bluetooth download images directory or other directory, pls manage to locate). Thanks hope this helps... Goodluck.
Oct 07, 2014 | Nokia Lumia 900 Smartphone Black Unlocked
Nokia 920 bluetooth code
When you pair any bluetooth device, its the code that you enter and this can be a code of your choice.You just need to make sure both devices have the same code for them to pair
Aug 01, 2014 | Nokia Lumia 920
Bluetooth will not go into pairing mode
Most bluetooth devices I have seen only have a blue light. They may have printed red/blue light so they can copy/paste these instructions for all models. I did find this video plantronics.com/pairing Most cases I have seen you turn on your head set, put phone in pairing mode then push the answer button and hold it til it flashes and the phone should find it as long as it is still searching for it.
Jan 28, 2014 | Plantronics M25 Bluetooth Headset
Plaintronics m25 will not pair!
Could be defective...
Try to entirely power off and then power on and try again
Nov 03, 2017 | Plantronics M25 Bluetooth Headset
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
I CAN NOT GET MY MOTOROLA EX115 TO PAIR WITH MY NOKIA BLUETOOTH
in your celfone click search new device bluetooth... if you see your model bluetooth device... it means pairing is done...
thank you...
Feb 01, 2011 | Nokia Bluetooth Headset Headset
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
3. Activate the Bluetooth feature on the phone, and set the phone
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Mar 03, 2009 | Nokia Bluetooth Headset Headset
Radio Communications Logo
56 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
