Question about Proscan 8" Tablet with 4GB Memory
Battery will not charge
Will show battery with no juice, but will not charge
    Sergeant:
  • 268 Answers
Make sure the AC charging adapter is actually putting out the correct voltage. You can get a cheap meter at places like Harbor Freight that will measure the voltage across the tip of the charging cable and the battery. If the tablet uses a USB cable for charging, try another USB cable and see if you get the same result for battery charging. IF you are already using the cable just to get power to run, it is probably the battery needing replacement. It is difficult to get these tablet cases open without the proper small tools. If the tablet is not under warranty, try taking it to a cell phone store - they usually have the tools to open these cases. Once you have the case open, look at the battery dimensions, voltage and maH capacity, usually on the battery label. Go to Ebay and try and find a replacement battery with the same size and voltage rating, preferably with a higher maH rating. Try searching for ProScan battery or by battery model number and you may get lucky finding a replacement.
Posted on Dec 04, 2014
How do I get my Eviant Android Tablet to turn on? I have had it for over a year and it was charging. I checked and it showed it was fully charged, but it will not turn on.
This is most likely your battery that needs to be replaced. A bad battery will show fully charged and not have enough juice to start the device up.
Mar 02, 2015 | Tablets & eReaders
Any solutions to dewalt 20v lithium battery charger got wet shows blinking light as if its charging normal but not charging
High Performance Current Mode Controller doesn't work for you in the charger. According to the link, scheme.http://kazus.ru/forums/attachment.php?attachmentid=51161&d=1377505983
Sep 18, 2014 | Dewalt 12v Max - 20v Max Li-ion Battery...
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
I can't get it to turn on. the battery shows a charge but nothing happens.
Its definately you`re Laptop charger.Its not pumping enough juice to power up your laptop. The battery will show a charge but it wont turn on,Its you`re power supply charger.
Ive seen this many times before.
Oct 18, 2010 | Computers & Internet
I have a polaroid pmp350-4 it doe not seem to charge. after 4 to 5 hours on charge the display shows minimal charge.
The answer is easy. Your computer USB is too weak to supply it juice needed. The best answer is to get yourself a wall power supply to usb that will give it more juice. You will know it is working when the battery that pops up on the screen actually MOVES from bottom to top more quickly than Sonic the Hedgehog moves versus the steady 'stay in place' or a snail's pace upward as I like to call it when plugged into the computer. You'll get your player charged in 2 hours versus 15 hours plugged into the computer and you have the bonus of the battery holding the charge better than the PC way where I've seen the battery be at the top and then you watch 1 video and it drops 4-5 bars. Use the faster, better charging method and it'll stay up there the whole time.
Oct 03, 2010 | Polaroid Audio Players & Recorders
Battery shows full charge, but when unplugged drains within minutes sonny vaio vgn-n220e
Battery most likely has dead cells, the live cell that is still working is showing 100% but does not enough juice to keep the computer running by itself. You need a new battery.
Jan 07, 2010 | Sony VAIO VGN-N220E/W Notebook
Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Mar 16, 2009 | Ryobi Drills
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
Proscan 8" Tablet with 4GB Memory Logo
162 people viewed this question
Top Proscan Computers & Internet Experts
David Payne
David Payne
 Mikey
Mikey
Are you a Proscan Computer and Internet Expert? Answer questions, earn points and help others
