Question about Crafts & Hobbies
I need help getting my talking silver express trin to run
I have an 1985-1986 talking silver rail express train set and it will move just a little ways and then stop. Has something happened with in the gear system?
My son recently disassembled one with the same symptom. He found one of the small gears in the drivetrain had split -- causing it to bind and limit motion to a inch or so. It's been in the family 25 years, but we elected to junk the locomotive :(
Nov 09, 2013 | Echo Toys
How do i get a decimal approximation for a logrithmic expression
Any logarithmic expression you will enter in a scientific (non-CAS) calculator will give you a decimal approximation. Just type in the expression and press ENTER.
Jan 22, 2012 | Texas Instruments TI-84 Plus Silver...
HELP! If anyones familiar with writing simple apps read!!!!
I truly do think you are trying to run before you can walk.
you at least need to know a little about scripting and preferably one programming language of your choice C+ or visual basic may be good choices.
Aug 01, 2009 | Microsoft Windows XP Professional SP3 Full...
Where is the low pressure line AC for Express 1500
Look for the accumulator(silver can a/c lines go to) on the passenger side of engine area. The Low side charging port cap should be on the side of the accumulator.
Jun 22, 2009 | 1996 Chevrolet Express
Expression Statues won't work
Sounds like a glitch. You may just have to start another game and hope this time the statues come out right. I saw someone else with the same problem on the fable 2 forums.
http://forums.projectego.net/bloodstone-expression-statue-help-11577/
May 24, 2009 | Microsoft Fable 2 for Xbox 360
Truble code p0400
the passage that causes this low flow is in the intake, it gets full of carbon and gunk, try running a wire through it, also make sure the EGR passes a functional test.
Dec 15, 2008 | 2000 Mazda 626
Microsoft visual studio 2005
Hi Manpreet,
I am working as a dot net team leader. I am GNIIT, and have 3 years of experience in dot net
you can download the express edition of Visual Studio 2005 from http://www.microsoft.com/express/2005/ express edition is free. Install the application and get going you can post any more questions here or you can talk to me at matharuajay@yahoo.co.in or ajmatharu@gmail.com
I would love to help you.
Oct 25, 2008 | Microsoft Mlf Visual Studio Enterprise...
Subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Nov 19, 2007 | Car Audio & Video
Parts is Parts!
panasonic should have the part, call 1-800-833-9626 the part number is LSEP3067 and should run around 460 USD.
you may be able to pick it up cheaper through Union Electronic Distributors, they don't normally stock it but i believe they can order it for you, should run around 300 USD. their phone number is 1-800-648-6657
hope this helps,
trin
Nov 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Car amp
if you are talking about speaker terminals i would have to know the model you are referring to. take a look at where the speakers hook up, you should have +-+- if it is bridgeable it will usually have markings below or above those that only show 1 + and 1 - ... connect your positive to the single specified and negative to the other specified... you may or may not be able to bridge it with a wire, without the amp model, i can not say for sure...
if you are talking about actual power connections, then yes you can bridge them, i have an old amp here that has 1 remote, 2 positives and a large negative.. i bridged the positives using 6 gauge wire and used a 2 gauge for the negative...
hope this helps,
trin
Nov 14, 2007 | Jensen XA92 Car Audio Amplifier
Crafts & Hobbies Logo
44 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
