Question about Philips 42PF9936 42-Inch Widescreen EDTV-Ready Flat-Panel Plasma TV
The TV is protecting its self every time I turn it on.. I have dissconnect both Y and X board AND I turned it on and still protects it self (Clicks once then twice, Light turns green then yellow then red while it's clicking)
  • Raul Gordillo
    Raul Gordillo Nov 27, 2014
    I have replaced it with 3 power supplies and still does the same thing! Every Time
    Scholar:
  • 152 Answers
If both sides are disconnected, the problem is likely on the PDP
S42 supply module.
It is a coincidence that the number ends in R1P.
Posted on Nov 26, 2014
Testimonial: "We have replaced it with 3 power supplies and still does the same thing every!"
It just turned off by it self and it wont turn on
TV is in fault protection mode. If the TV relay clicks on then off and the Fault LED starts blinking. You have bad/blown capacitors on the PSB-Power supply board. Recaping the blown UF caps works 90% of the time.
Jun 30, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Do thunder lightning has any effect to a sony bravia lcd or a panasonic viera lcd tv?
Yes!!! When going out for extended periods of time unplug TV's from a/c outlet AND dissconnect broadcast signal from TV(cable,sat. etc)
Isolation is the only sure protection against LIGHTNING DAMAGE!!!
I advise purchasing protection from your' service provider.
May 19, 2010 | Televison & Video
What does it mean when my plasma tv turns off by its self? its a panasonic viera plasma tv have had for bout two years
Basically when it turn itself OFF automatically all the time, the TV goes into "Protection Mode". This happens when there is a damaged circuit board inside the need to be replace and turn itself OFF to protect the other ones from being damaged.
A TV service tech will have to look at it to find out which boards need to be replace. There are about 7 different boards in your TV that would cause this problem.
Nov 01, 2009 | Panasonic Televison & Video
Intermitant power off
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No Power
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
Good Luck, big IRISH....... sory if was tooooo loooong
Sep 18, 2008 | Mitsubishi WS-55807 TV
Turns on and turns off.
Good Day;
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
GREEN LIGHT FLASHING
Good Day;
Sep 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 no power
Good Day;
Aug 18, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv turns off by it self
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
May 29, 2008 | Philips 60P8342 60" Rear Projection...
Where is the Dm board? Does anyone have a picture for this model
Sep 07, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Philips 42PF9936 42-Inch Widescreen EDTV-Ready Flat-Panel Plasma TV Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
