Question about HP Photosmart C8180 All-in-one - Multifunction Printer /
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
When running the self test Diagnostic Page, black ink in spots running down the left side of paper. Yellow is green & light green. No Light Cyan or Cyan. Light Magenta & Magenta are blue and white lines.
  • 101 Answers
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Posted on Nov 22, 2014
4 Suggested Answers
SOURCE: different colors on the scanner screen
I didn't find a fix. I went to Best Buy and they said it would cost more than it was worth to fix. So I bought a new one. Thanks, mittenshadow
Posted on Jun 11, 2008
puertobori
  • 7733 Answers
SOURCE: scanned items display red, green and yellow
go to HP Support & Drivers 1
Posted on Oct 13, 2010
SOURCE: My printer does not print the color red. The
Press the 'Menu' button on the printer's control panel. Use the arrow buttons to highlight 'Ink Levels' then press the 'Ok' button to view the cartridge's ink levels.
Open the printer's front cover to replace the color ink cartridge if it shows a low ink level. Wait for the ink cartridges to stop moving.
Press the tab on the front of the color ink cartridge and lift the cartridge out of the printer. Remove the wrappings from the new cartridge and install it in the printer until the front tab clicks.
Clean the print head by pressing the printer's 'Menu' button, then selecting 'Clean Printhead' and press 'Ok.' Press the 'Ok' button again to start the printer's print head cleaning process.
Run the print head cleaning three times; if red still will not print, replace the printer's print head. Remove both print cartridges by pressing on the tabs while you lift each one out of the printer.
Press the button in the upper-left corner of the assembly and remove the print head. Unpack the new print head, remembering to remove the orange cap, and press it into the assembly until it clicks into place. Reinstall the print cartridges until they snap into place as
well.
Reference: http://printers.iyogi.net/problems
Manual below.
h10032.www1.hp.com/ctg/Manual/c00437630.pdf
Posted on Nov 13, 2010
Why too much yellow and red no greens or blues ?
Inkjet printers use additive pigments. CMYK, Cyan, Magenta, Yellow and Black. It sounds like you're not getting any Cyan ink to the paper. Either your printer is out of Cyan ink, or your Cyan print head is clogged.
Go into your printer's Properties and run a Nozzle Check. It will print a series of lines with each color. There will probably be a big empty space where it tried and failed to print Cyan. You can try cleaning the print heads, but if you're getting NO Cyan that is unlikely to work.
If you're lucky, your printer is one of the ones that the print heads are built into the ink cartridge so replacing the cartridge will resolve the problem. If you're not, you might need to get it serviced (or probably more cost effective, buy a new printer).
Apr 30, 2014 | Epson Stylus CX5700F All-In-One InkJet...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
Feb 15, 2008 | OKI C9500dxn Led Printer
HP Photosmart C8180 All-in-one - Multifunction  Printer / Logo
163 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
