Question about Radio Communications
Have motorola hx550, broke boom its my favorite blue tooth an cant find one can you please help,thank you
    Master:
  • 382 Answers
SOURCE: ear hook
Contact Motorola and tell them the situation. They will send you new ear hooks. I've done this twice since they don't have replacement parts available publicaly
Posted on Mar 18, 2008
  • 27 Answers
SOURCE: how to connect motorola skywing
The default passkey is usually 0000 (4 zeros)
Posted on Jul 23, 2008
ManOwar1
  • 16 Answers
SOURCE: plantronics 220 blue tooth
Another bang bang solution...
Be sure to charge your headset for atleast 15-25 minutes minimum to get a starting charge. This will also give you 15-30 minutes of talk time to test out your headset and placement, and also get used to being a part of the bluetooth generation.
Once charged, press the call button(the big button on the side) and hold it down until you see a flashing red/blue combination of lights, now you only have 2 minutes to set this up, or you have to start over.
Once the lights are flashing on the headset, it is searching for a phone, now you go to your phone, and find your options for connectivity or bluetooth, once in your menu, look for the option to search or connect to a blue tooth device. Let it search/connect automatically.
Once it is connected, the flashing lights on your headset should stop, finish the connect process on your phone, if it says found it, install it, entering device data, etc etc, follow everything it says by entering YES, hitting OK, or CONTINUE.
Once it says CODE or PASSWORD to enter for your bluetooth device, enter 0000 .Which is ZERO ZERO ZERO ZERO and then press enter.
It should take 2-10 seconds for the password to initiate, record into your phone, and pair your device. This is a detailed explanation. Please rate me for my effort.
ManOwar
Posted on Aug 07, 2008
SOURCE: instruction manual for blue tooth
In order to pair the Sprint Freedom Pack #GKX2880X, the headset needs to be on. Then press and hold both the "+" and the "-" keys until the blue light remains lit. The passkey code requested by the handset is four zeros.
Posted on Nov 30, 2008
SOURCE: motorola h700 will not turn on
It is not a major problem.Sometimes this might happen due to phone settings.
Please refer the manual in the following link.
http://www.motorola.com/mdirect/manuals/QSG-H700_9499A88B.pdf
Posted on Dec 10, 2008
Bluetooth pairs but will not connect
Try pairing and connecting with another headset. Or delete the pairing and pair again.
Mark
Motorola Support
Aug 21, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
Hx550: Cant hear out of it
Connected to what phone? Have you unpaired and re-paired to your phone?
Mark
Motorola Support
Apr 10, 2014 | Motorola Mobility Hx550 Universal...
Motorola HX550 works fine but will not charge at all
Quincy
Charge with Boom closed. Reset headset HX550 Reset to factory default then repair.
Mark
Motorola Support
Jan 08, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
CAN U HELP ME SET MY BLUE TOOTH UP?
Close The Headset Boom And Hold The Multifuntion button until theheadset indicator turns on then release and open the boom. Then its OnDiscovery Mode And The Code Is 0000. Pairing IsSuccessful when the indicator on the headset flashes 10 times. The Light Being Onsteady is pairing mode.
Also Click Here For Your Manual
Please Rate Our Experts
Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 16, 2009 | Motorola Mobility HS850 Consumer Headset
Blue Tooth
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the headset boom, repeat steps 1 through 3
Jun 26, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
I can not use my blue tooth
boom is closed)
Ensure that your phones blue tooth is active and looking for a new device
Jan 13, 2008 | Motorola Mobility H700 Headset
Motorola blue tooth pin code
Yes there is a universal code. It is 0000. That is four zeros.
Hope this helps :)
Oct 25, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Music Folders
you have to use blue tooth and blue tooth it from your computer.
Aug 20, 2007 | Motorola Mobility V360 Cellular Phone
Radio Communications Logo
108 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
