Maytag MAF 1260 AAW - hums and does not expel water or spin
Maytag MAF 1260 AAW - hums and does not expel water or spin. To Test, I have unhooked the water out hose and put it directly into the floor drain. Now when filling up - water just drains out... Is this normal?
  • 695 Answers
I think the pump is bad, jammed up with something, or just stuck. You said it was humming. It seems to be trying to work. You will have to go in there and see. GOOD LUCK FRIEND.
Posted on Nov 17, 2014
  • bleech Nov 17, 2014
    That was it! Pulled the pump out and found two 10 cent pieces, now working normally. Thanks Danny!
  • 96 Answers
SOURCE: Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
Posted on Mar 02, 2008
SOURCE: Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Posted on Jan 22, 2009
Joe Onley
  • 363 Answers
SOURCE: new inglis washer expells water when fills
seems like no one wants to send you any love Richard. Well fear not, if you haven't figured this out yet, I'll do what I can. It seems to me that you have the drain hose lower than the top of the wash basket or a hole in that hose. If the drain hose is too low, the water will run out of the machine due to low center of gravity. Ideally, 6" above the level of the tub is sufficient. If there is a hole in that hose, replacement is pretty straight forward.
Posted on Aug 27, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
  • 4 Answers
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Posted on Mar 20, 2010
Maytag centennial washer - not draining on some settings
Check outlet hose for kinks or restrictions. Make sure the outlet hose is free to expel water at full volume. Make sure the outlet hose is not mounted to high. Check pump impellor has all it's vanes intact. Check for coins in all hoses & pump.
Dec 21, 2013 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag mvwc6esww1 motor hum
There is a good chance that the hub and seal need to be replaced. The Direct drive coupling might be the problems too. I looked at some Maytag parts seller and this part (hub and seal) seems to be unavailable. Have a qualified person opens the front panel and check the direct drive coupling. If the coupling is good, your are left with the hub and seal or the transmission wich is too expensive.
Jan 22, 2018 | Maytag Washing Machines
Maf 1375 AAW front loader washing mahcine - water wont drain out???
Remove the back access panel. On the bottom of the tub you will see the drain boot. Remove the boot from the tub and check for any blockage. Also, while you have the boot removed, check up in the tub for any small pieces of clothing that may be hung up in there.
Feb 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Leaking water for washer machine
Check your drain, drain hose (make sure the clamp is tight) and check the pump to make sure that all hoses are attached properly
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Atf 6000 front loader not spinning or draining
HI .you probably have a no drain problem. remove bottom panel. the pump is on the right. put drain hose on the floor, in a bucket, drain water out. check the pump. remove the hoses to the pump. clean out. thanks the appliance doc please rate my answer.
Oct 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Dehumidifier emptys in the floor.
Check the float first - be sure the styrofoam on the bottom is still intact.  Be sure that you can move it up and down freely (and easily) with the bucket out of the machine.  If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself.  It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger.  The machine should cut out immediately - if it does not - the microswitch needs to be replaced.  (they're very cheap, and simple to replace)
Sep 13, 2008 | Maytag M7DH45B2A Dehumidifier
Washing machine will not drain
Please fill your washer with a very small amount of water, turn it to spin and tilt it back. You should be able to see the belt on the bottom turning your pump. I ask you to verify this because imporper belt tension or a bad thrust bearing can keep it from turning improperly. If it turns freely on this test, Then you have something plugged up. Drain the water out. Next unhook the hose that goes between the tub and the pump at the tub side. You can get sock or other small articals of clothing in there that will prevent draining. If that is clear. It is likely you have had another coin go through your hose that goes between the pump and the wall. They can get quite a ways in there and maytag hoses get smaller right before they end. If you have a coin in this area you will need to work it all of the way back to the pump side of the hose.
Jun 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
