Question about Kenmore 24" Built-In Dishwasher with Ultra Wash System and TurboZone
Why will it only wash through a whole cycle if i am leaning on the door?
  • 579 Answers
For safety reasons manufacturers started to put switches on washer lids so machines would not run with lid open. Your problem is with your switch. It may have wore out, or through use broken a small piece off it's end, not allowing the switch to fully engage. When you lean on the door, you are helping the switch fully engage. Look around the perimeter of your lid and you will find the switch. GOOD LUCK FRIEND.
Posted on Nov 17, 2014
Tecnik Washing Machine 9290 Red light not gone out so not able to open door. I switched it off by mistake but put it on and did the whole cycle again but still on and unable to open door . Please help
from the manual always WAIT.
DOOR
Use the handle to open the door.
During the wash and dry cycle, a special safety device keeps the door locked.
To open the door, turn off the machine using the ON-OFF push-button and wait about 30 seconds after the switching off the warning light before turning the handle to open the door.
also...
WARNING: Set the cycle only when the machine is off. - Always turn the control dial clockwise. If you pass the desired position, make a complete turn and reset the dial to the
exact position.
Jul 25, 2016 | Tecnik Washing Machines
I have power but no cycle will start
Sorry but when we see no MAKE and model listed there is little we can do . Many times it turns out to be the door switch has failed .try leaning against the door when pressing start button .
Jan 31, 2016 | Washing Machines
Washing machine water not draining even finished the whole cycle? ANYONE have same problem? please help, thanks
I have had this when over filled my washer, repeat spin cycle several times and eventually the water will be goneso the door will open. Note turn power off if the cycle is set by rotating dialor more water may go into machine
Oct 15, 2015 | Washing Machines
Why wont my machine run quick cycle it fills up,drains with 43mins on timer?
Power control board is not seeing what it needs to continue . perhaps the door switch , try leaning against door
Sep 14, 2015 | Washing Machines
Ecologixx 7. Why does it keep switching itself off?
could be the door switch has failed . try leaning on door when starting .
Sep 13, 2015 | Bosch Washing Machines
I set the dishwasher Siemens SL84A to regular wash cycle . I hear it click like its going to start, warm water fills the bottom up the tub but it never kicks into the wash cycle. Hit the cancel cycle and...
Most likely issue here is that the door is not sealing properly or the sensor on the door is not working, so it can fill up much as your washing machine does but just as the washer won't spin without the door closed neither will the dish washer. An easy way to check this is to let it fill and then lean or push against the door some and see if it starts, if so then the issue is the isn't sealing properly.
Dec 04, 2013 | Siemens 24 in. SL84A305UC Built-in...
Frigidare front loader won't spin during wash cycle
Does the washer go throught he whole cycle and just not spin? Or does it just shut down? If it goes the the whole cycle, You either have a bad door switch or a bad control board. Replace the door switch first. Then the control board 2nd. Door switch is a very common problem with these washer.
Feb 10, 2009 | Frigidaire GLTF2940ES Front Load Washer
ATF7000es E10 fault
Hi - it sounds to me like the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw. I must have plenty of those to be spending my time here :-)
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
May 12, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
Dec 07, 2007 | Dishwashers
Kenmore 24" Built-In Dishwasher with Ultra Wash System and TurboZone Logo
62 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
