Question about Frigidaire Washing Machines
Stuck on washing cycle
I just put this dishwasher together and trying it for the first time but it is a used unit and the previous owner swears that it worked fine. I selected 'light wash', no heating requirements for washing and drying and pressed the start button. the machine filled the water and is getting stuck on the 'washing' cycle every time. I tried this several times but is getting the same results. My machine does not have a display error code panel, only little lights for selections made and cycle indicators, washing, drying and clean.
  • Official Brand Answer
  • 2,267 Answers
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
Posted on Nov 18, 2014
  • 641 Answers
SOURCE: Drum filling with water
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Posted on Sep 09, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
ngfam1
  • 639 Answers
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • 6 Answers
SOURCE: Ariston Dishwasher LI 675 DUO
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
Posted on Jan 14, 2010
  • 10 Answers
SOURCE: Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Posted on Dec 27, 2010
Which detergent to use in Fisher & Paykel dishwasher?
some women swear by Cascade . I swear by hand washing myself .with Dawn
Feb 25, 2015 | Fisher Dishwashers
We have a Bosch SHU3307UC dishwasher. Two friends swear by theirs, saying they put everything in dirty and the load always comes out clean. That does not at all work for us. My wife has to just about wash...
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
Nov 28, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Du1100xtpq7 dish washer keep repeating wash cycle doesn't go past this just keeps washing
Hi
Thanks for using FixYa. If the cycle doesn't complete, check these:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Leaks during wash and rince cycles
hi, Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Jun 25, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
Timer
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Jan 03, 2009 | Dishwashers
Miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Jan 05, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
Washing Machines Logo
143 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
