Maxell 191048 mouse drivers
Nedded drivefor windows xp sp3r a/o instalation sw
4 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Unresponsive mouse XP unable to initialize device driver for Logitech LX8 laser mouse
Your best course of action would be to use System Restore, based on your response above. Go back to the point where everything worked for you and don't attempt to update your driver again. If it works, don't fix it.
After that if there was something you wanted to accomplish, let us know and we can help you.
Regards,
Worldvet
Posted on Oct 17, 2008
durham_darre
  • 150 Answers
SOURCE: need mouse driver for mouse #76H6620 for win xp
Just google it and I am sure you will find someone that has the driver you need...
Posted on Sep 01, 2009
  • 733 Answers
SOURCE: Belkin F8E814 optical mouse will not work properly
re-install the drivers for your device.
Posted on Apr 05, 2010
My mouse worked just fine until I moved across town. It does not work now. Why?
Hope the Wireless transmitter (adapter) on laptop is still ints place.
Try to unplug and re-pair with mouse.
Mar 08, 2016 | Maxell 191048 Black Wireless Ergomotion...
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
How do I open it?
there should be a door on the bottom for a battery replacement. otherwise they are not made to be opened .
Aug 07, 2015 | Maxell 191048 Black Wireless Ergomotion...
How do I turn the mouse off/on?
Hi Charles,
According to:
Product Description Color: Brown
The Maxell 2.4 GHz Wireless Safari Mini Optical Mice have more than cool looks. Since they are 2.4 GHz wireless optical you'll notice less signal loss. They also have 3 key buttons and a scroll wheel so you can speed through your computer programs. The Maxell mice are wireless so you don't need to worry about wires getting in the way. They can detect a computer up to 32 feet away. These are compatible with Windows 7, Vista, XP, 2000, ME, Mac OS 10.0 or above. Requires one AAA battery.
- So i do believe there is no on an off button on that mouse as I read on this site that says: "This one doesn't have an on/of switch, so in order to turn it off you have to disconnect the USB every time and store it underneath the mouse (annoying) . also, if it's idle for a minute (maybe less) the mouse goes in sleep mode and you have to disconnect the USB to wake it back up (super annoying) . The mouse works fine, it just gets old having to take it in and out all the time".
Amazon com Maxell 2 4 GHz Wireless Safari Mini Optical Mouse Brown...
May 03, 2014 | Maxell 2.4 GHz Wireless Safari Mini...
How do I turn the Safari Mouse off?
Hi Charles,
According to:
Reinstalled windows, run sw cd of mouse, driver installed, only registry not changed . usb pendrive is also not detected , in win98& xp
I would suggest looking up the drivers on the manufacturers database but if you are using '98 and XP it is not likely.
USB pen drives were not invented in 1999 when XP was used.
Feb 16, 2011 | Computers & Internet
Usb mouse on laptop
go to start>>control panel>>add and remove porgrams.
uninstall all of the Logitech software related to the optical mouse.
restart the computer, plug in the mouse usb, the windows OS should automatically detected the mouse.
Windows OS has logitech mouse driver buldin. you don't need additiona; software.
Nov 04, 2008 | Computers & Internet
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Mouse problem
usally xp dosent need mouse to get installed . windows xp i sdesigned for supporting all human interface dvices like keyboard and mouse .. normal xp other than service pack 2 need some drivers . check whether the set up program is designed for windows xp . if not right click propertiess of .exe file go to comaptability there u acn find run this program comaptabile for 98 ,nt , me etc sect the driver version and install
Dec 04, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
