Question about Roku XDS Streaming Player 1080p Wireless-N Dual-Band (2100X)
How do I set up Wi-Fi?
I need to set up Roku with Wi-Fi on my Visio or Samsung TV. I have the Visio TV in another room a few rooms from the router.
    Habit-Forming:
  • Roku Expert
  • 94 Answers
First, you will need you network password, if password protected. Next, connect your Roku device to the television nearest your router.
Start your Roku device, and wait for the Roku main-screen to appear. Then scroll down to "Settings" and hit "OK" on your Roku remote. Next scroll to "Network" and hit "OK' on your remote, then choose wireless, or wired. If you using an Ethernet cable to connect your Roku, you won't need a network password. If your trying to make a wireless connection, this wireless choice is where you'll need your network password.
Posted on Dec 16, 2014
I have a roku stick in my living room and my bedroom also have a wiifi extender but in my bedroom I am getting too many cutouts with the red circle what can I do or are you having problems
Sounds like weak signal problem or slow wi fi speed. Locate your wi fi transmitter as high as possible. Also check out your wi fi speed to make sure it isadequate for your service.
Sep 17, 2017 | Roku Televison & Video
I have a Roku in my bedroom & when I try to watch Netflix it just spins & spins & takes forever to load. Once it starts, it stops & starts spending again.
First step, of course, is to unplug the Roku for 10 seconds then plug it back in again and let it connect.
Assuming a Wi-Fi connection is what you are using, it is possible (likely) that your Roku is too far from the Wi-Fi router. Your best solution is to relocate the Wi-Fi router closer to your Roku, or to get a signal booster to extend the range of your Wi-Fi signal.
On a more technical note, your Wi-Fi router may be broadcasting on a channel that has lots of conflict with other Wi-Fi signals in your neighborhood. Changing the broadcast channel requires that you have an administrator login to your router and can make changes. You might have to call your service provider and have them make the changes for you (if you smile right over the phone, they may give you your router's login information, but don't count on it). Best channels to select are generally 1, 6 or 11 to avoid overlap with other channels.
If you have a smart phone and can download an app, look for a Wi-Fi Analyzer app (free). This will show you the other signals around you, what channel they are broadcasting on, and the strength of the signal.
Sep 06, 2017 | Computers & Internet
I need to get rid of cable, What is the fire stick and how does it work?
Hi Robin. I have never used fire stick but I do have ROKU in 3 rooms in my home and I get lots of free movies, news, sports tv shows etc. Works from Wi-Fi. https://www.roku.com/index
Apr 26, 2017 | Televison & Video
CAN SAMSUNG TV MODEL PN43D430A3DXZA be connected with wifi to show you tube videos
Your TV is not wi fi capable. Best bet is to get a ROKU player. It will connect wirelessly to your router so you can get You Tube videos.
Oct 13, 2016 | Samsung Televison & Video
Where do I find the IP adress so I may connect manually.
https://wwwimg.roku.com/static/oldlib/roku_player_documents/rokuplayerug.pdf
page 23 change network settings
then page 14 on wi fi settings
if new service provider gave you the encyrption key and has dhcp on then this should start Roku working on Wi FI.
New service provider would have installed a wi fi router this is most likely on 192.168.0.1 or 10.0.0.1 go to cmd prompt type in
ipconfig
then press enter key
Not the default ip address
the router should have a wi fi security option that tells you if the wi fi is encrypted and what ssid is being broadcasted.
DCHP should be enabled Roku will use this to assign itself an ip address once connected to Wi FI.
you need to know routers admin user name and password as well
Apr 18, 2016 | Roku 1
How do I get it to work?
Roku® Streaming Stick® offers all the channels through HDMI
https://www.roku.com/products/streaming-stick
Roku, Inc.The small size of the Roku® Streaming Stick® means you can easily plug it into ...Roku Search makes it easy to find what's on, where you can watch it for free, ... At a wifi-enabled hotel or dorm room, just use your connected device to sign in ...
Roku Streaming Stick® (HDMI® Version) (Model 3500 ...
https://support.roku.com/.../208754808-Roku-Streaming-Stick...
Roku, Inc.Connect your player Step 1: Insert the Roku Streaming Stick (HDMI Version) (Model 3500) into an available HDMI port of the TV. ...
Roku Streaming Stick Review & Demo - YouTube
? 5:03
https://www.youtube.com/watch?v=mSqMMJSPkBU
Oct 29, 2012 - Uploaded by totalhtpc
Many described the Roku Streaming Stick as one of the most promising ... My Tv does not have MHL port how to use thisRoku stick? thank you.
Dec 19, 2015 | Roku Streaming Stick
It's connected to my wi fi but it's telling me it can't connect to roku it says error code 011
The E011 error code is usually a router firewall problem. If you can turn off the firewall in the router when installing Roku that may solve the issue. This is not to be confused with the computer firewall in Windows which is left ON. When you go into SETTINGS/NETWORK your screen should look similiar to the attached picture. 25351243-jkwiv2v3rghcuytcwoewo3pc-1-1.jpg
Jan 02, 2015 | Roku Streaming Stick
Not really a problem...yet...I have Verizon and have 6100F Westell Modem/Router. I would like to purchase a blue ray player and get Netflix...I know I need a blue ray player that works with Netflix...what...
If your object is to get Netflix on your TV, and not knowing what brand or model TV you have nor whether or not you have an existing wi-fi system, that question is a little difficult to answer. For example, I have Suddenlink cable, wi-fi, and can access Netflix and other similar providers through either my TV or TiVo, although I always go through TiVo. You may need to update your TV.
Sep 18, 2017 | Westell Wirespeed ProLine 6100 Router...
I am trying to set up my roku with my router and I cannot find roku.com/link on the web.
Place the Roku box on your TV or entertainment center and plug it into the wall outlet. Connect the box to your TV with the included AV or HDMI cable. Insert the included batteries into the Roku remote.
  • 2 Turn on the Roku and the TV. Press the "Input" or "Source" button on the TV remote until the Roku menu appears. Follow the instructions until the wireless setup screen appears. Use the remote to select your network and input your Wi-Fi network access code, then press "next."
  • 3 Turn on your computer and log in. Start your Internet browser and type "roku.com/link" in the address bar. Press "Enter."
  • 4 Set up a Roku account if your don't already have one. Enter the code that appears on your TV screen to finish the setup process.
  • Read more: How to Set Up Roku Wireless ' eHow.com http://www.ehow.com/how_7459834_set-up-roku-wireless.html#ixzz1AZ8NBDhQ
    Jan 09, 2011 | Computers & Internet
    Roku XDS Streaming Player 1080p Wireless-N Dual-Band (2100X) Logo
    166 people viewed this question
    Top Roku Televison & Video Experts
    David Payne
    David Payne
    Thomas Stauber
    Thomas Stauber
    ray gallant
    Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
