Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Cannot get the DVD to work. Takes disc in, displays "loading disc" for several seconds, then goes to wide screen white screen showing 1080 pix mode, then just ejects disc. Never even starts to play the movie.
    Top Expert:
  • Toshiba Master
  • 74,473 Answers
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 17, 2014
romsky79
  • 822 Answers
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
Posted on May 28, 2009
  • 47 Answers
SOURCE: Two DVD's stuck in Toshiba Regza with built-in DVD player
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Posted on Jun 25, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: wife put another DVD in 32" Regza LCD with DVD, now 2 are stuck
Open it up. Once opened they are pretty easy to figure out.
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: how do you play games on a regza toshiba tv
What game system are being set to this tv?IF PS3 use a HDMI cable for connection to play.
Posted on Oct 12, 2009
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
Cannot remove dvd
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Performance chips for ford
Jun 12, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
My dvd wont eject. when i press open it blinks for a minute then goes to loading! then dvd will then play. I can hear it running but it will not eject the dvd.
unplug it for 10 - 15 mins... when you plug it back press the stop/eject quickly (player will automatic try to load disc)
Aug 09, 2011 | Toshiba SD-6000
I have Toshiba Regza 32 with DVD and the disk got struck. It doesnt play or eject. But you can hear the DVD is on, is working. The TV works no problem. How I can ejects the disc from the DVD. Please help!...
Hello
As you feel DVD is woking, that is spinning inside, and there is no picture at all, the fault will be with its defective Laser Pickup Unit. It is a common fault , that this unit bcome damaged. No special rason can be pointed out for that. Just put a cleaning disc into the player, and play it for two or three times. If the fault is due to dust or dirt accumulation to its pick up lens, it will be alright after this procedure. If it does not help, there is no other way than replacing the Laser Picup Unit, with same type and number. OK.
Apr 06, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
All I can get on my tv is a blue screen - sometimes its says no video input but I've checked the cables and they are fine.
I can't get regular tv to work. I'm able to play dvd's but when I eject the dvd only the welcome screen shows.
Nov 18, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Why won.t the disc go to load. it keeps opening after inserting disk .when play is pushed it shows stop then ejects disk.Whats up with www.rca.com/customersupport
check the type of discs that are recognized with your dvd player. Some machines recognize dvdr- some dvdr+ some dvdrw+/- you may be using the wrong formated type of disc.Look at disc and see what type it is in the ring surrounding the hole especially if it is a copy
Sep 29, 2009 | RCA Televison & Video
Toshiba Regza 32 inch with DVD player - won't eject
Disconnect cable from DVD to TV, press play, and then press stop, try to push eject button to get the disk out. If all could not have, you have to open the DVD cover then get the disk out.
Aug 18, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
