Question about Miele 24 in. G665 Built-in Dishwasher
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
    Novelist:
  • 269 Answers
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Posted on Nov 25, 2014
4 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: How is element removed from Miele Dishwasher
Procedure to remove element :)
http://www.acmehowto.com/howto/appliance/dishwasher/repair/heatingelement.php
Thanks.
Posted on Jan 06, 2009
  • 177 Answers
SOURCE: Miele dishwasher not heating
hi,
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Posted on Jan 22, 2010
SOURCE: hi my miele dishwasher g665 no hot water or drying
new heating element
Posted on Jan 27, 2010
Wanting new inside racks for the Miele G665 current ones are starting to rust
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 21, 2010 | Miele 24 in. G665 Built-in Dishwasher
I need a new timer for my miele g 665 dishwasher, were can i buy it?
hi,
spares are only available through Miele spare parts or their registered service agents who will probably then source the part from Miele spare parts anyway.
Dec 15, 2009 | Miele 24 in. G665 Built-in Dishwasher
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Miele g665 dishwasher
Wow... one week is a long time. Those dishes has to be very clean or at least worn out by now.
From what you are discribing, it appears you have a timer control module that is malfunctioning. You might try that first. If that still doesn't do the trick, check the fill valve sensor/seliniod
Jun 09, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele g665
Peter,
where is the water coming out at? Are you using the proper detergent? if the machine is too full of water and a fill float valve is stuck open, water sometimes overflows.
Check to make sure the fill valve is working, then check to make sure pump is operating. (you will know when you turn the machine onto the rinse cycle.)
Mar 17, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele no heat
The last I checked, the G660 will not work for the G665. If you look under Applicances in your phone book, you will see several appliance repair places. Most of them can get you universal kits to replace this. I however caution however that you should really let a tech look at your dishwasher. Something tells me that boards got shorted out by mistake without realizing it.
Mar 10, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher element?
dispenser is not linked that will be the solinoid valve on the dispenser. the heater could be open circuit or on the side of the wash motor is a pressure switch that is common for blocking so it will not put the heater on.
Feb 12, 2008 | Dishwashers
Miele 24 in. G665 Built-in Dishwasher Logo
281 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
