Question about Amazon Kindle Fire HD
How do I shut off volume in an app.
How do I find settings to shut off sound to an app?
    Sergeant:
  • 320 Answers
In many applications once the app is open you can press the volume up / down buttons to adjust the volume in that application. Many times however the volume will effect the whole device and not just that app. so notification sounds etc will also be lower.
Posted on Nov 18, 2014
Sound not working on my tablet
hi Claire.
How do you fix the volume on your tablet? To verify the volume when audio or video are not playing:
  1. From the home screen, tap All Apps.
  2. Scroll to and tap Settings.
  3. Tap the DEVICE tab.
  4. Tap Sounds and notifications.
  5. Tap and drag the Media slider to the preferred volume.
Troubleshoot audio playback issues on your Samsung Galaxy Tab 4
https://support.sprint.com/.../WTroubleshootingGuide_542_GKB76043-dvc8270006prd Search for: How do you fix the volume on your tablet?
you could try this link as well.
no sound on tablet
or this one.
Sound not working on my tablet Google Search
Nov 27, 2017 | Tablets & eReaders
How can i increase the volume? Even at maximum level it is barely audible!
Look for a volume control in your settings section. Sometimes the settings volume is down & the app volume is a secondary control that can only go as high as the settings(or master) control, Turn it up and you regain control from the app you are running.
Aug 05, 2015 | Tablets & eReaders
I have a brand new I Pad Air that has circulating blue boxes that are accompanied by an annoying female voice that interferes with everything. How do I shut it off?
It sounds like you have enabled Accessibility options. You can turn them off by
  • tapping your settings app
  • selecting Accessibility
  • Touch VoiceOver
  • slide the green slider to Off
  • close the Settings app by double-clicking the Home key
In Accessibility, you may also wish to turn on the Reduce Motion setting.
May 06, 2015 | Apple iPad Air
I used to get audible notifications re texts but now I don't
firstly check if your volume is not all the way by going to the home screen and increasing the volume.
second go to the setting then notifications and check the app in question it might have auto turned off with an update or something.
PS: I haven't used an apple device in a long time but im pretty sure its in the setting the under 'notifications' if not there then maybe under the 'sounds' tab
Mar 10, 2015 | Apple iPad Mini
Low sound can hardly hear it even tho the sound is turned high
Sometimes the app you're using has it's own sound control that overrides the device sound setting. Look in the app for sound settings, eg audiobooks apps often have a separate setting for volume and this is the one that you need to adjust.
Jan 01, 2015 | Tablets & eReaders
My volume is not working even when I turned on but still nothing happend I powered off then back on but still nothing happened
Now Jennifer, do you mean the sound or the volume controls? I assume you mean the sound. In that case, can you hear anything when you plug in headphones? Is there a little headphone icon displaying on the screen? Can you make the volume bar display and move it up and down?
In Settings > Audio Profiles, you can choose ringtones and such, and set the volume levels of various audio sounds. It will also play a sample of ones you select, which is a quick way to see if the audio works.
You can install the "Z-Device Test" app from the Play Store, and it tests all sorts of things on your android. Maybe it can help.
Sep 26, 2014 | Avatar Android Tablet 7" 2nd Gen Single...
How do I get the sound on my ipad apple 16gb
Go into settings: notification center : check your apps to make sure the sound is on for that app.
Sep 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
No sound on ipad
1. If you have no sound at all, even in the Music App, try rebooting the iPad.
Reboot the iPad by holding down on the sleep and home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider if it appears on the screen - let go of the buttons. Let the iPad start up.
2. If you lost sounds for keyboard clicks, games or other apps, email notifications and other notifications, system sounds may have been muted.
System sounds can be muted and controlled two different ways. The screen lock rotation can be controlled in the same manner as well.
Settings>General>Use Side Switch to: Mute System sounds. If this option is selected, the switch on the side of the iPad above the volume rocker will mute system sounds.
If you choose Lock Screen Rotation, then the switch locks the screen. If the screen is locked, you will see a lock icon in the upper right corner next to the battery indicator gauge.
If you have the side switch set to lock screen rotation then the system sound control is in the control center. Swipe up from the bottom of the screen to get to control center . Tap on the bell icon and system sounds will return.
If you have the side switch set to mute system sounds, then the screen lock can be accessed in the same manner as described above.
This support article from Apple explains how the side switch works.
http://support.apple.com/kb/HT4085
3. Try cleaning the dock connector opening of the iPad with a soft brush and just a little bit of rubbing alcohol.
4. Reset all settings. Settings>General>Reset>Reset All Settings.
Aug 12, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
How do I turn the volume up when it won't turn up with volume control?
If you hold the power button down a menu pops up - the last option is for mute/unmute. Make sure this is not set to mute.
If this doesn't help, it could be that some app you are running is muting the sound. Close all apps and see if that helps. Power off/on and see if that helps. If you do determine it is an app that's causing the problem, add a comment about it in the Play Store so the developers will know and hopefully fix it.
Jul 27, 2014 | ASUS Google Nexus 7 Tablet
How can i turn volume on my dopo m975
(Tap the settings icon in app launcher to get to the settings menu)
Go to settings then device sound
set volume levels and turn sound ON/OFF
Feb 02, 2013 | Tablets & eReaders
Amazon Kindle Fire HD Logo
49 people viewed this question
Top Amazon Tablets & eReaders Experts
castletech
castletech
Martin Murray
Jax Planet
Jax Planet
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
