Question about Locks & Locksmithing
ILCO SINGLE CYLINDER JIMMY PROOF LOCK 530-53-51 need inside view to reassemble please
2 Suggested Answers
  • 963 Answers
SOURCE: i can't remember the code
I have reviewed the installation instructions and in the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
"This is a lost combination situation.
Please call our Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331."
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Posted on Aug 24, 2011
Reassemble ILCO deadbolt guts.
Check YouTube to see if there is a video on this. Most anything anymore someone has gone through pains of repair and recorded it to share
Nov 25, 2014 | Deadbolt Locks & Locksmithing
RE-SETTING THE CODE
You need a key to unscrew and remove the lock cylinder on the inside of lock. Enter the old combination. Look inside the hole where the lock cylinder was and turn the metal part in there to the right. Then turn the knob or lever to clear the old combination.
Enter your new combination and turn the knob or lever to insure it works. Try it again to be sure, then replace the change plug. Always test combo with the door open.
Apr 22, 2014 | Ilco Kaba 101126d41 Lock Combination
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
How do i get the handles off and take lock off the door
I'll direct you to the installation manual.You are doing the reverse of an installation. (Step 6 Page 14 can be performed with a flat screwdriver.)
If you cannot open and view it, you will need to download and install Adobe Reader on your computer, because the instructions are in a PDF file.
Get the manual download here:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Go to the grid page and click on PDF under the "Manual" column, across from "1000"
There is a link on the top right to get Adobe Reader if you cannot view the manual download.
Aug 16, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to re program our kara ilco when i swip the gma card it says card error or wrong card is being used
The Kaba Ilco 1000 lock does not use any sort of card reader for programming--it is strictly a push button lock.
From this link, which you can cut and paste into your web browser:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
you can search for your model of Kaba Ilco lock and click on the box with the picture of your lock.
This will take you to the page for that particular lock. On the right side of any given page, you will see the heading "Documentation" an under that, a link that says "click here to visit the literature and support page".
Following that link will lead you to a grid of the various lock models, with links to the manuals, etc.
These will be PDF files and will require you to have Adobe Reader installed on your computer to view them. If you don't have Adobe Reader, : http://get.adobe.com/reader/
You will also find a "Contact Us" link on the first link I gave you, where you can contact Kaba Ilco directly for customer and technical assistance.
I hope I've been able to help. Good luck!
Mar 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Iv'e got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the...
Here is a link to the Kaba Ilco web page which has a grid chart, including the L1000 series lock:
Of particular interest to you will be the Manual (page 10) and Parts List, which shows an exploded view of the lockset. Hopefully this will give you the info that you need.
On the same webpage you will also find a link "Contact Us" for further technical information and parts.
Also on that page is a link to get Adobe Reader. If you don't already have it installed on your computer, you will need it to open the PDF files for the manual and parts list.
Hope this helps. Good luck!
Mar 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How do make my simplex lock magnet proof
Call Kaba and ask them to send you a form, which they will - fill it in, send it back, and the kits to fix the alleged problem arrive a few days later. Note that it's likely they are already magnet proof unless you want to lug a 90lb magnet around with you, despite what the video alleges.
Mar 13, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hello I'm having problems with trying to remove the override cylinder from the old cypher lock to install in to the new one. Is there a special way or special tool I need to remove it?
I can't help you directly, but I can steer you toward some information.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Feb 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I was relocating a working Kaba m# LL101126D41 i had happen to turn the outside handle with the small key cylinder removed on the back side top now when all installed it wont lock . what do ineed to do...
Oct 13, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Single cylinder dead bolt only works with key
You are 180 degreees out of sync with the other side of the bolt. Take it apart and move your key 180 degrees and reassemble and try it. Im 51% sure this is your trouble
thanks for posting at FixYa.com
Please vote
thanks
a
Nov 15, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
47 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
