Question about Epson Expression Premium XP-610 Small-in-One Wireless All-in-One Printer & Extra Black Ink Package
Do I have to replace the color ink cartrigdes in my epson xp-610 printer
I do not wish to replace the color ink in my printer, but I have replaced the black ink. However, my printer seems to be stuck in a loop that will not let me print until I replace the color cartridges.
    Top Expert:
  • Epson Master
  • 14,161 Answers
Q:
How do I change the ink cartridges?
A:
Do the following:
Removing and Installing Ink Cartridges
Make sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Leave your old cartridges in the printer until you are ready to replace them to prevent the print head nozzles from drying out. Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
  1. Make sure that the CD/DVD tray is not inserted for printing.
  2. Turn on your product.
    • If an ink cartridge is expended, you see a message on the LCD screen. Note which cartridges need to be replaced and press OK . Then select Yes, replace now and press OK .
    • If you are replacing a cartridge before you see a message on the LCD screen, press the left or right arrow buttons, select Setup > OK > Maintenance > OK > Ink Cartridge Replacement > OK . Then press the Do I have to replace the color ink cartrigdes in m - start_black_icon.jpg start button.
  3. Lift up the scanner unit.
    Caution:
    Do not move the print head by hand; otherwise, you may damage your product. Do not touch the flat white cable inside the printer.
  4. Push in the blue tab to unlock the ink cartridge you are replacing. Then lift the bottom of the ink cartridge to remove it.
    Warning: If ink gets on your skin, wash it thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If ink gets into your mouth, spit it out and see a doctor right away. Keep ink cartridges out of the reach of children.
  5. ReDo I have to replace the color ink cartrigdes in m - ink_recap_xp600_800.jpgdge using the cap that came with it.
    Note: Dispose of used cartridges carefully. Do not take the used cartridge apart or try to refill it.
  6. If you are replacing the Black (BK) ink cartridge, it is recommended that you shake the new cartridge gently four or five times before unDo I have to replace the color ink cartrigdes in m - ink_shake_xp600_800.jpg need to shake the Photo Black (PBK) cartridge or any of the other color ink cartridges.
    Caution:
    Do I have to replace the color ink cartrigdes in m - ink_package_open_xp600_800.jpgter opening the packages, or ink may leak.
  7. Remove the cartridge from the package.
    Caution:
    Do not touch the areas shownDo I have to replace the color ink cartrigdes in m - ink_cap_remove_store_xp600_800.jpgl operation and printing.
  8. Remove the cap from the cartridge and store it in the bag that came with your product for later use.
    Note: Save the cap so you can recap ink cartridges before storing or disposing of them.
    Caution:
    Do I have to replace the color ink cartrigdes in m - ink_cartridge_insert_xp600_800.jpglabels or seals, or ink will leak.
  9. Insert the ink cartridge head first into the ink cartridge holder. Then press the bottom of the ink cartridge down until it clicks into plaDo I have to replace the color ink cartrigdes in m - ink_cartridge_scanner_unit_lower_xp600.jpgp://i.fixya.net/uploads/images/ink_cartridge_insert_xp600_800.jpg" alt="ink_cartridge_insert_xp600_800.jpg" class="h_mi" />
  10. Once you replace all the cartridges that need replacing, close the scanner unit.
    The product starts priming the ink. This takes a few minutes. When you see a completion message on the LCD screen, ink replacement is complete. Note: If you see an error screen telling you an ink cartridge is installed incorrectly, lift up the scanner unit and press the ink cartridge down until it clicks into place. When you\'re finished, close the scanner unit.
If you remove a low or expended ink cartridge, you cannot re-install and use the cartridge.
Caution:
If you remove an ink cartridge for later use, recap the ink cartridge using the cap that came with it to prevent the ink from drying out and to protect the surrounding area from getting smeared by ink. Store the ink cartridge in the same environment as the product. Do not leave the product with the ink cartridges removed for an extended period of time. Otherwise, ink remaining in the print head nozzles may dry out and you may not be able to print.
http://youtu.be/xJsDu52txEA
Posted on Nov 18, 2014
SOURCE: Printer will not print black, but will not let me replace black cartridge
Had the same problem but this worked for me. To force a cartridge change, press and hold down the PAPER FEED button for at least 5 seconds as suggested here:
http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=313630&data=qBjAbS6NcI3fNMgp8+fHGGs5vImpFwyM
I then changed the black cartridge, even though I hadn't used much ink from the old cartridge and the computer was showing it as three quarters full.
Posted on Apr 22, 2008
SOURCE: Epson Stylus Color 660 won't print in black
hi i want driver epson 660 in windows xp pls help me
Posted on Jun 08, 2008
  • 2692 Answers
SOURCE: Epson DX8400: how can i get it to print black only
Sorry Desperate. All inkjet printers, from all companies,  are programed to only operate with ink in all containers to avoid other problems. Their is no workaround. Please rate me not harshly just  because you don't like the answer. Rate based upon the truth of an answer.
Posted on Mar 11, 2009
  • 121 Answers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Posted on Apr 28, 2009
websnail
  • 419 Answers
SOURCE: Epson Dx5050 blocks any printing once it has
Unfortunately you cannot override this behaviour without installing a valid cartridge in the printer.
Epson printers do not have this sort of functionality as it would leave the printhead open to damage and foam clogging.
Sorry to be the bearer of bad news.
Posted on May 19, 2009
What does 0xEA error indicate?
Do you know how to check ' what is printing'? If you do, please check and delete all unwanted list on the printing queue. Switch it off completely and disconnect all the cables leave it for a few minutes and reconnect the cables and switch on. It should work.
Nov 07, 2015 | Epson Expression Premium XP-610...
Epson Stylus COLOR 880 will not show ink level on computer Window XP
Go to epson web. Download updated driver and "Status Monitor" software.
Feb 18, 2013 | Epson Stylus 880 InkJet Color Printer
My epson xp-200 printer with won't print with the recommended ink cartridge epson 200. why?
The printer may only work with Epson ink cartridges and not compatible ink cartridges.
Sep 15, 2012 | Epson Expression Home XP-200 Wireless...
Hi, my epson stylus SX210 had ran out of magenta ink, can i still print if the black ink is still full in it?? Naoimh
These printer required replace cartrigde empty to continue printing
You must replace only the cartrigde empty
T0711 Black
T0712 CYAN
T0713 MAGENTA
T0714 YELLOW
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do I refill ink cartridges for Epson Artisan 810 Printer?
The ink cartrigde would have been provided with an injection kit to extract and install. In any absence, refer to the retail for installation kits for replaceable ink or refills.
Jan 29, 2011 | Epson Office Equipment & Supplies
Have an epson stylus rx585 610 series printer replaced cartridges keeps telling me to replace cartridge over and over. Using genuine ones, clicked in properly etc what is the proble???
http://www.misterinkjet.com/epson_resetter_instructions.htm
www.ssclg.com/epsone.shtml
www.bismut.net/manual-reset-for-epson-stylus-color-printer/ - 14 hours ago
www.fixyourownprinter.com/forums/inkjet/16333
OK check all those out there are tools to help you reset you ink cartridge and printer anyway have a good look.
May 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
We have Epson ink jet printer. It worked fine when we got it last month but now the pictures are really awful - the colors are blurring and running together and there are recurring horizontal streaks...
Maybe the ink cartrigde is running out. Get sure that the cartrigde has enough ink, if it has not then reload it. If it has enough ink, then review that the printhead be clean, (you could clean it by using Isopropyl alcohol), then you can use the tools included in printer software to align or maintain cartrigdes. If this does not fix the problem, then replace the cartrigde.
Apr 20, 2010 | Epson Office Equipment & Supplies
WHEN THE INK CAPS ARE FILLED CARTRIGDES LEAK FROM THE BOTTOM PART
I Would Stick with Epson Genuine Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to fix CISS Unit to Epson RX 610 printer?
replaced all ink colours and now a colour print is almost all black and white with a tinge of magenta? how can i fix this
Mar 29, 2009 | Epson 6 Color Inkjet 5760x1440dpi Photo...
How to change cartridges on an Epson Color 760???
hold the paper button until the cartridges move to the left position where you can change them
Jm
Jan 01, 2008 | Epson Stylus Color 760 InkJet Printer
Epson Expression Premium XP-610 Small-in-One Wireless All-in-One Printer & Extra Black Ink Package Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
