Question about Blenders
Memory Healer Program is claiming to cure Alzheimer's with a blend of natural fruits and herbs. Is it legitimate?
GASKET ON MY MIXER MODEL # 362490 WAS CHEWED UP, NEED A NEW ONE ONLY TWO WEEKS OLD!
we can not assist you with this we did not sell you the blender as we sell no products .try the proper website .
Jan 12, 2016 | Blenders
What is the best blender for making smoothies with frozen fruit?
There are many types of blender available on the market which perform a different operation. Some blender is famous for specific work. I would suggest you choose the blender which can perform all the blending operation perform in the kitchen. Ninja Professional Blender BL160, BL660, BL482, Cosori High-Speed Blender.
This all is the best budget blender for smoothies. You can get the comparison of all these blenders in one place, then you can choose the best one which is suitable for your kitchen.
k2-_dc60fae0-5edf-426c-815f-45fa26bb0c57.v1.jpg-a8dba74604930421996186d49210837d5e1c6aed-optim-450x450-1idkyi3fqqfoabkjwactfx1g-2-0.jpg
Jul 28, 2015 | Vitamix Blenders
How do I eliminate excess froth from a fruit blend
try adding a tablespoon of cornstarch it makes a great defoamer i use it all the time
Jan 06, 2015 | Magic Bullet Nutribullet Blender
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
When trying to blend things like frozen fruit or frozen yogurt with the Vitamix, the blade stops moving, but the motor continues running. Even if there's only enough frozen yogurt to cover the blades, it...
Frozen elements are generally not recommended for blenders of any brand. They may cause the blade assembly to stop moving completely, or to "bog down," and this may eventually damage the motor. It is recommended that frozen fruits and/or yogurt be thawed when possible before placing into a blender. If this is not a possibility for you, I would use a "pulse" or "chop ice" function to rapidly spin the blades for just a moment. This will chop the contents in smaller, more manageable parts. This should be done before adding other liquid ingredients.
Jul 09, 2009 | Vitamix Blenders
Poor function of my Oster classic blender
Yeah, the blades probably need to be replaced. The replacement blade assemblies for most models can be ordered directly from Oster - their phone # is 1-800-334-0759 - you have to go through an elaborate menu tree to get to the right place.
Apr 03, 2009 | Oster 4093-8 Osterizer Classic Blender...
Instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise 1 egg (or 1 egg yolk) 1 teaspoon of lemon juice 1 teaspoon of herb vinegar 1 pinch salt 1 pinch pepper 1 ½ - 2 cups of oil 1 teaspoon of french mustard Put all the ingredients except the oil in a jug (not too large) and blend well with the WHISK. Then add the oil in a thin, steady stream (not drop by drop), processing all the time, until the mayonnaise has reached the required consistency. To achieve perfect results, all ingredients should be at the same temperature.
go back
Dec 13, 2008 | Bamix Deluxe Handheld Blender
Open Questions:
Blenders Logo
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
