Question about Craftmade International Dryers
Change the light bulbs in the log cabin on the top of the fan for model LC52EB?
The lights inside the log cabin at the top of the fan (model LC52EB) are burned out, and I am trying to figure out how to open the log cabin to replace the bulbs.
    Top Expert:
  • Craftmade In... Master
  • 3,698 Answers
Www.craftmade.com/
Posted on Nov 17, 2014
How do I change the light bulbs inside the log cabin on top of the fan?
Does this fan have bulbs built into the motor base?
Nov 17, 2014 | Dryers
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
CHANGE LIGHT BULB I BATH FAN
According to Broan's site - the model you specified has no light bulb - check specifications - you can search the site for the proper model and download the instructions.
http://www.broan.com/products/product/4108f1af-c993-4327-982f-1174f091fd6f
Apr 12, 2014 | Broan-NuTone Broan 110 CFM Premium Bath...
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson microwave oven with grill mwg9115sl
You need to remove the top cover and the light could be seen mounted on the side of the cabin. You can access this by removing the guard and the bulb can be replaced with the same type rating. If the bulb has not fused then check on the door switch and power from the board.
Jan 31, 2013 | Microwave Ovens
Need to know how to replace the rear window brake light bulb in a 2009 hyundai sonata. Thank-you.
Unplug the connector in the trunk.
Remove the 2 gold-colored screws from inside the trunk. They can be seen from the trunk. One of them is thru the larger square opening where the wire connects to the high-mount brake light. The second is on the right side thru a small (screwdriver width) hole covered by a piece of foam tape.
After removing the 2 screws, go inside the cabin and the brake light housing pops right up.
Disconnect the bulb from the housing while inside the cabin.
Back in the trunk, remove the wire and bulb. The wire from the connector to the bulb socket should be about 5 inches long.good-day !
Oct 25, 2011 | Hyundai Sonata 09 2009
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Change the lightbulb
take the outer case off light will be accessible for you to change it
Dec 08, 2009 | Microwave Ovens
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Where is the light bulb located?
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO BIGDEEL
Do you mean your internal cooling fan or the hood / vent / exhaust fan?
If it's ther internal cooling fan, do not use the microwave or the magnetron will overheat and be damaged or destroyed.
Jun 23, 2008 | GE JES1288SH Convection/Microwave Oven
Dryers Logo
113 people viewed this question
Top Craftmade International Dryers Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Rani wadia
Rani wadia
Are you a Craftmade International Dryer Expert? Answer questions, earn points and help others
