Question about Video Game Consoles & Games
How and which hard drive or external hard drive do i use for my older Ps3?
Its the orignal ps3 not the ps3 slim
  • 3 Answers
Just plug a normal external drive and make sure it's formatted in FAT32. Should work fine.
Posted on Nov 17, 2014
Tip
How to remove the hard drive on a Playstation 3 Slim Removing the hard drive on...
Removing the hard drive on the PS3 Slim is simular to removing the hard drive on an original PS3, however the drive is in a different location.
Note if you are upgrading PS3 hard drive you will need to back up your data first so that you are able to put your files back onto the new hard drive.
1. Make sure you have all your cables unplugged from the PS3.
2. Turn the PS3 upside and locate the hard drive access door (it will be at the front of the system next to the small info sticker).
3. Ether with your finger nail or a small screw driver lift up the cover.
4. Next carefully unscrew the blue screw. Note you will want to make sure you get the right size phillips head to make sure you do not strip out the screw head. On the few systems I have seen a PH1 head you be the right size you need.
5. After you have the screw removed you will want to slide the hard drive cover to the right to expose the hard drive.
6. Next pull down on the lever and pull strait back in the drive caddy to remove it from the PS3.
If you have remove the drive to upgrade the drive you will want to unscrew the drive from the caddy and install your new drive.
If you have removed to corrupted data on the hard drive the link below will walk you through formatting the hard drive on your computer just skip to step 4 as the first steps are for removing the hard drive from the original PS3.
How to fix PlayStation 3 corrupted hard drive
on Oct 08, 2010 | Sony Playstation 3 Slim Console
Tip
How to fix PlayStation 3 corrupted hard drive If your PS3 will not fully load...
If your PS3 will not fully load and you are getting a message that the hard drive is corrupted. Go through the options in recovery mode. The link below will help cover those options.
http://www.youtube.com/watch?v=yZWye1CLTVo
If you have gone through the recovery mode options then you may just need to do a full format of the hard drive or there is something wrong with the drive.
Note with a normal hard drive from time to time a sector will fail on a drive. Normally Windows will fix the this with on of the backup sectors on the drive but in the case of your console systems this may not repair the drive.
1. Next what you will need to do is remove your hard drive from your PS3. To do this you will need a small flat head screw driver to pop the hard drive cover off. You will see a tap on the right side to put the screw driver in.
2. Next you will want to remove the lock screw that holds the drive in place. Normally it is green.
3. Next lift up the lever and pull the drive back to the right into the open space. This will disengage the drive from the PS3.
If you are needing the steps to remove the hard drive from the PS3 Slim go to this link. How to remove the hard drive on a Playstation 3 Slim.
Note after you get the hard drive removed from the PS3 you do not have to remove the drive from the caddy that the drive is in.
4. Now you will need to connect the drive to your computers SATA hard drive port and powersupply. Note if your computer does not have a SATA connector and/or you have a manufactured computer like a Dell or HP you may not be able to connect your hard drive directly to the computer. They make USB external kits that will let you connect the drive externally via USB.
5. Next you will want to boot your and open My Computer. After my computer is open you will want right click and select format for the drive that is from the PS3. The format options should open up. You need to make sure that the "Quick Format" option is not check. Note be sure that before you click Start on the format that you are selecting the drive for the PS3.
Note if the Full Format hangs then this is a sign that there is actually a problem with the hard drive its self.
Also note if you have the drive connected to the internal connectors it will show up like a standard drive but if you have it connected externally it will show as a removable drive. If you do not see a extra drive letter you may need to assign one to the drive the links below will help you set a drive letter.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
6. After you format the drive you will want to put it back into the PS3. When you put it back in you will be prompted to format the PS3. The PS3 format will setup the drive for use with the PS3.
Note you may need to reload the firmware on the PS3. If you need to do this you can get the firmware and instructions to install it from this link.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
At this point you should be able to use your PS3 as normal. If you still have trouble then you most likely have a problem with the hard drive its self.
on May 20, 2010 | Video Game Consoles & Games
PS3 Slim powers completely down after 30 seconds- no video.
It's gotten so hot it's like the yellow light of death but that's on the older models... It's in the CPU or gpu
Mar 27, 2014 | Sony Video Game Consoles & Games
Can a old ps3 hard drive go in a slim ps3?
yes jst unsrew d side panel and insert d new one in man
Sep 12, 2012 | Sony Playstation 3 (PS3) Console
My old ps3 got ylod. i got a new slim works perfectly fine. i figured i should put my 60 gb in it to format it so it doesnt go to waste but the formatting stops at 99%. when i put my slim hard drive back...
Formatting writes data to the disk, should a sector of the disk be damaged the hard drive may not report it to he PS3 firmware. If you can install the hard drive in a computer hard drive repair utilities, like spinrite, can often fix such problems. http://www.grc.com/spinrite.htm
Connecting it to a computer and doing a low level format there is likely to have better error correction than the built in PS3 formatting.
http://www.youtube.com/watch?v=bRBVkFysdqg&feature=related
Aug 08, 2011 | Sony Playstation 3 (PS3) Console
Red light blinking.it cost me thousand of pesos to buy ps3 cards and now ps3 not working.is there any means i can get my ps3 working and why the hell ps3 design a had drive that cannot be transfered to...
You are best off buying one of the new PS3's, as they do not have the Hard Drive problems that older ones have. I had an original PS3, tried two hard drives with it, but both became corrupted. I lost a lot of data because of this. The new PS3's have additional precautions such as auto-shutdowns (no possible force shutdown) and a better start up after a game freezes (no damage). I have the 80 Gb (Not slim). I recommend getting this version, instead of spending money trying to fix an older one.
Dec 02, 2010 | Sony Playstation 3 (PS3) Console
How can you connect a seagate 250gb external hdd to a ps3 120gb
i have just bought a seagate external 1tb hdd to store more stuff on but it wont connect to my ps3 slim 120g what can i do
Nov 16, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How do you change memory from one play station to another without having a memory card can you do it with a usb or external hard drive??
You can indeed use a Memory Stick or external hard drive. You just plug it into the USB port on the PS3 and then manually copy and paste each save data on the memory stick/hard drive. Then just bung them on the new one. I did this when i got the new PS3 slim. Your trophies get automatically transferred when you sign into your new ps3. Hope this has helped.
Jun 15, 2010 | Sony Playstation 3 (PS3) Console
Help brand new ps3 hard drive corrupted. Im not taking the hardrive out, HELL NO!
I would return for replacement if it is new. Or send to sony would be under warranty if under 1 year. If not warrantied try to format the hard drive.Replace hard drie if it is older style PS3 and not the new slim PS3. I think the hard drive is built in and cannot be removed. If is a slim, your best bet is the warranty. Good Luck.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
