Question about Vehicle Parts & Accessories
What does a dual mass flywheel do? - Vehicle Parts & Accessories
    Problem Solver:
  • 19 Answers
The DMF [dual mass flywheel] protects the driveline from potentially damaging torsional vibrations of the engine which enhances driving comfort, by reducing transmission noise and harshness. What does a dual mass flywheel do? - 25286655-j2tkupuwqhtxxv4hjgxzj2dw-2-0.jpg
Posted on Nov 24, 2014
Flywheel replacement
Not enough info?? Are you asking how to replace flywheel or what flywheel you need? Dual mass to single mass conversion??
Mar 28, 2014 | 2004 Jaguar X-Type
Replaced transmission now it will not start
some vehicles have crank angle sensor fitted to belhousing, by removing trans can damage the sensor or may be forgot to connect the socket. also if its a manual and has a dual mass flywheel then excessive play on dual mass can upset the crank angle sensor timing
Apr 06, 2013 | 1997 Chevrolet Suburban
Starter motor is jamming
NO,when the dual mass flywheel goes you will feel it.starter motor jamming is normally down to worn teeth/release spring.
Apr 26, 2010 | 2001 Ford Focus
When fitting a new dual mass clutch, how do you know which way to bolt it on as the holes are not offset in any way
Align the dowel pin on the crankshaft to the smallest hole on the dual mass flywheel.
Jul 22, 2009 | 2002 Nissan Xterra
Does not rev up when taking up a small incline,heavy noise coming from clutch. Have replaced cluth and pressure plate for the second time.The selection of gears are very hard , does not select well. Iwould...
There is a company in Northern Ireland called Exact Engineering that can convert your dual mass flywheel to single mass using a complex engineering process ending with a finely balanced guaranteed single mass product. They have a complete courir service.
You can see their website at www.exact-spec.com and contact them at info@exact-spec.com
May 03, 2009 | 2003 Jeep Liberty
96 FORD F-350 7.3 TURBO DIESEL 5 SPEED
no, it shouldnt have any looseness to it and dual mass flywheels are VERY expensive to replace, BUT yes it can be converted to a solid flywheel, check out autozone.com part number MU1989 or advanceautoparts.com part number 798, that should get you on the right path to curing your problems, i welded the two independantly turning discs of my dual mass flywheel together but i wouldnt recommend anyone doing that without the proper equipment to do so (i.e. precision lathes, cast iron welding rods, etc)
Mar 29, 2009 | 1996 Ford F350 Crew Cab
1996 F-350 7.3 TURBO DIESEL 5 SPEED MANUAL
The best thing to do is to take it to a transmission shop and ask them. They will be able to tell you if it is bad. This is the cheapest way to find out if it is bad and you can ask them how to tell for future knowledge.
2003 Tiburon 6 spd clutch replacement now tranny won't respond
Possibility, you may have intalled the clutch disk backwards.... if so, the disk hub is torqued against the crankshaft hub preventing engagement of the clutch. 2003 TIBUORN DUAL MASS FLYWHEEL AND CLUTCH DISC ASSEMBLY INSTALLATION PROCEDURE DESCRIPTION: The 2003 MY 2.7L Tiburon vehicle equipped with the 6-speed manual transaxle employs a dual mass flywheel system. The 2003 Tiburon Shop Manual does not show the clutch disc assembly with the dual mass flywheel. This bulletin provides information about how to assemble these components. NOTE Although it is possible to assemble the clutch disc with either side facing the flywheel surface, only the assembly of these two parts shown in this bulletin is correct.
PARTS ASSEMBLY:
  1. Attach the dual mass flywheel to the engine crankshaft assembly.
  2. Identify the clutch disc flange side and the collar side as shown. 0240025a.gif
  3. Install the collar side of the clutch disc on the dual mass flywheel surface so that the flange side is facing the pressure plate side as shown. 0240025b.gif
  4. Attach the pressure plate to the dual mass flywheel and complete assembly of the remaining components per the Shop Manual procedures. 0240025c.gif
Dec 14, 2008 | 2004 Hyundai Tiburon
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
